PARKE wrote on 2025-08-03, 21:35:
My opinion is that we should not overthink this stepping thing. Steppings were done for various reasons, fixing bugs was a major reason, and steppings that were substantially 'better' to such an extent that we mortals would actually notice a difference are not that common. Even when a certain stepping was for example a bit faster the difference may have been subtle enough to level out differences between individual chips i.e. the 'best' chip of the earlier stepping may be faster than the worst of the later one.
Pretty much. There is always a variance between the quality of the individual chips themselves within a batch, which will often play a much bigger role in the particular chips overclockability then which exact stepping it is. This is true more often then not.
The question shouldn't really be "which is the best/latest stepping for a mmx cpu ", but, "which cpu originating from ANY of the problem-free steppings just happened to originate somewhere near the middle of the wafer and is likely to have the best quality "
