Hercules/Guillemot 3D Prophet II GTS 32 BIOS
First post, by lkawa84
Hello,
I am looking for a BIOS for Hercules/Guillemot 3D Prophet II GTS 32 MB, the one from VGA Legacy (https://www.vgamuseum.info/index.php/cpu/item … ia-geforce2-gts) does not work. Perhaps the card is damaged, but I would like to try again. The card is detected under Windows 98 and the wfflashe program detects it, so it seems to be a problem with the BIOS.
Reply 1 of 24, by randi
i dont have any hercules BIOSs but, one idea i have used recently is unload your BIOS from the card to a file in dos, using debug.exe, and then use that BIOS as virtual BIOS to boot up the 86box virtual machine. You can verify if the BIOS was good or not that way. i would start by checking if 86box supports that particular card first.
Reply 2 of 24, by lkawa84
randi wrote on 2025-08-04, 17:46:
Unfortunately, the original bios is damaged and nothing can be done with it.
Reply 3 of 24, by randi
Damaged, as in pins missing? how did you conclude that?
Reply 4 of 24, by lkawa84
randi wrote on 2025-08-05, 19:10:
I meant the original BIOS file for the card. After downloading it, it only takes up 5 KB, which seems a little too small, and it is mainly filled with zeros. It looks like someone tried to save a different BIOS earlier and something went wrong.
Reply 5 of 24, by Nexxen
It's 77KB for me.
contains 3 files, 65,45,65KB
Maybe your download is wrong?
You have the blue Hercules?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 6 of 24, by lkawa84
Nexxen wrote on 2025-08-06, 17:46:
It's 77KB for me. contains 3 files, 65,45,65KB […]
It's 77KB for me.
If it's the same card, can you share your BIOS with me? Photo of my card:
Reply 7 of 24, by Nexxen
lkawa84 wrote on 2025-08-06, 18:23:
It's 77KB for me.
How do I extract that?
Tomorrow I'll check if it the same, but looks like it.
Reply 8 of 24, by dm-
fort tests you can use any gts bios. if the card is alive then flash to hercules.
Reply 9 of 24, by lkawa84
Nexxen wrote on 2025-08-06, 21:45:
It's 77KB for me.
I used wfflash, which can be downloaded from the link.
ELSA Synergy II -32 PCI: No VGA output - BIOS bit rot?
Reply 10 of 24, by lkawa84
dm- wrote on 2025-08-07, 03:59:
If I don't get the Hercules BIOS, I'll try this way.
Reply 11 of 24, by PC Hoarder Patrol
The full package for the 64MB model is easily found (attached) and is the same version (2.15.01.07.00) as the hercules.bin file from VGA Legacy, though can't find an equivalent package for the 32MB model.
The attachment b3dp264-107.exe is no longer available
Reply 12 of 24, by Nexxen
PC Hoarder Patrol wrote on 2025-08-08, 04:25:
Maybe an input select for 32 or 64 with a soldered zero ohm resistor somewhere?
I had that with a now dead 128 and 256 versions of a card (some ATI).
You open one more address and you double the fun 😀
I'll try to image the bios I have this w/e. I need to setup a board just for that.
If this one above fits the bill I won't.
Reply 13 of 24, by lkawa84
I tried using this BIOS and got the following result:
Reply 14 of 24, by lkawa84
Here is a photo of what Windows 98 shows.
Reply 15 of 24, by Nexxen
Well, I'll do something later today to get to your bios image.
Maybe I can save it from W98, that I have as an AGP machine.
Question to the pros: could it be a bad attempt at BIOS modding, bricking the card to an extent?
Reply 16 of 24, by Nexxen
lkawa84 wrote on 2025-08-07, 16:30:
This is my bios file.
Checksum is 0045tB00.(44KBytes)
0 are zeros not letters
Reply 17 of 24, by lkawa84
Nexxen wrote on 2025-08-10, 13:44:
This is my bios file. Checksum is 0045tB00.(44KBytes) […]
I tried using this BIOS, but unfortunately nothing works. Thank you for your help. Maybe someone else has an idea? Here are some photos from my attempt.
Reply 18 of 24, by Nexxen
lkawa84 wrote on 2025-08-10, 17:14:
Could be a dead BIOS chip.
If you have a spare you can desolder this one and try a swap.
Reply 19 of 24, by dm-
nvflash detects gpu even without soldered eeprom.
most likely gpu/card is damaged
