MRVFONE wrote on 2025-08-06, 10:28:
Newer versions of firmware would be very interesting. They would help with testing modems etc. The main reason would be to fix specific modems. I have had a few where the flash chip has lost/be corrupted etc. So i have a eprom burner etc.. which i use a lot. So that would be a big help there.
I have been collecting dial up modems for quite a few years. In the end i would like to have a real modem on my BBS that i'm going to build again. I ran a BBS back in the mid 90's. I love retro computing ALOT.. so it will be a fun project 😀
T.
Thank you for the extra context.
If you want to use vintage modems for a BBS and restore said modems in general, I understand.
I doubt many people here collect dial-up modems. I had a "fascination" with them that extended well past their heyday. As a consequence, I still have a few dial-up modems, mainly external serial ones. Almost all are USR branded and are upgraded to v.90 or v.92.
AFAIK, the fastest on e could get if setting up a BBS would be v.34bis connectivity, unless one manages to get something like a decommissioned modem bank from an ISP and convinces a telco to lease the kind of line required for that bank to inteface to the telephone network digitally.
That being said, I wonder if it might be possible to tap into a VOIP ATA that allows disabling compression and somehow hooking up something like a modem bank (that can modulate 56K through its digital uplink). There was a thread about using a fax or modem over VOIP a while back.
Barring having a special setup, v.34bis is the most that can be expected. I suspect that most any consumer modem that was released beyond the late 90s and was 56K capable probably had v.34bis firmware that was quite stable. Even v.90/v.92 implementation probably fossilized not much later.
That being said, if you need firmware dumps from specific old modems, you might get lucky by asking around here, but I would not expect many people here to much of a modem collection.
Best of luck on the BBS project.
