Windows 95 vs Windows 98
Reply 20 of 42, by Jo22
Virtual PC for Mac used to emulate a Pentium MMX PC.
So at least from a compatibility point of view, this was alright for the whole 90s.
Photos of VPC 4 can be found here: Re: 1996-1999 emulation status in 2025?
Reply 21 of 42, by Robbbert
I wouldn't use 95 for any new build, there's just too many missing features, and its general instability is not what you want.
Win98SE is fine - my main gaming machine (mostly 3D DOS FPS games) has been running fine with this OS for a long time.
Reply 22 of 42, by Namrok
Robbbert wrote on 2025-08-12, 10:38:
Can confirm, if you want a Win95 machine, you have to really want it. I set up a P233 with Win95, and it's a constant pain in my ass. With zero configuration changes, every now and again the NIC will cause the system to hang and I have to boot into safe mode and disable it. For reasons that are inexplicable to me, certain games that are supposed to be Win95 compatible (Diablo, Sid Meier's Alpha Centauri) cause it to bluescreen. But not always? Actually Alpha Centauri's problems didn't begin until after I updated it from the 1.0 version on my physical copy. This machine has a Riva 128, and for whatever reason the latest reference Win95 drivers have bug in them that don't occur in Win98. The manufacturer drivers seem better? But I also suspect some of my bluescreen problems are related to the manufacturer drivers being older than the reference drivers?
If it were my only machine, I'd start over with Windows 98, no question. But it's not, and I really do want at least one Windows 95 machine in my stable, before the IE integration and the active desktop and all that stuff.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 23 of 42, by marxveix
I use Win95a or Win95b if the PC is too low at speed and hard drive space!
I have Win95b with DX6.1 + Vga + Audio+ Network + some windows 95b updates all on 64MB HDD.
64MB HDD, not 64GB! All extra suff over 10/100 LAN Network or over USB 1.1, that USB is also slow.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 24 of 42, by chinny22
I agree with the MMX and below your better off with Win95
MMX and above Win98 SE
Even WinME can makes sense for a late Win9x box
Its Win98 first edition that I struggle to find a use case for.
Reply 25 of 42, by leileilol
Win95 giving up out of the box after 350mhz should be a hint. 😀
chinny22 wrote on 2025-08-13, 00:03:
1998 period correct early adopter torture!
Reply 26 of 42, by RandomStranger
Back then I used Windows 98 on my Pentium 100 MHz and after an upgrade 200MMX with 32MB RAM. And a friend of mine 2 or so years later ran XP on a Celeron-333A with 64MB RAM. From a retro perspective it doesn't make much sense. I'd draw the line for W98 at the 200MMX
Reply 27 of 42, by bertrammatrix
Windows 98 on everything for me. Fast 486 and up with 64mb of ram or more should have no issues with it.
Reply 28 of 42, by AncapDude
I would also say 98 runs fine on 486-66 or higher with 32mb RAM or higher. I would go for 95 OSR 2.1 below one of these conditions only.
Reply 29 of 42, by Jo22
AncapDude wrote on 2025-08-13, 14:47:
I would think same. As long as it's not a Compaq ProLinea 4/66.
Had one and installed Windows 98SE on it, nearly cried in tears.
Saying it was a "sluggish" experimence was an understatement.
I don’t know why, but Windows 98 was on its knees on this PC.
Reply 30 of 42, by gerry
similar for me, it's the ram mostly - 32 or more seems about fine for 98se. 95 just seems a bit unnecessary and ME seems to restrictive (and a bit more demanding)
I'm like that with windows 2000, which is fine when ram is around 128-256 but after that xp is fine while vista 32bit is too demanding to be worth it and w7 32 bit likewise - except for some newer drivers etc
and vista 64 seems about the same as w7 64 bit in hardware demands so i'd prefer w7 on almost any 2core+ 64bit system, while w8 i dont much like and w10 is a bit 'heavy' and seems better on quads with 8+gbram
windows editions have these patterns for me 😀
Reply 31 of 42, by GemCookie
I'll take Windows 95 on any hardware. Both operating systems are horribly unstable, but 95 at least runs significantly faster, even on a Pentium 4 system. I also have a soft spot for the underrated releases – I've skipped 32-bit Windows XP for 2000, XP x64 and Vista on several of my machines.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 32 of 42, by Kane 93
You are definitely a oddball GemCookie 😀 I do love Windows Vista I got it dual booted With Windows XP i7 3770K 32GB RAM and a 780TI. I was going to go for a 980TI but it really is pointless 😁 For my other retro PC I have Windows 98SE and Windows XP dual booted on a 440ZX PC with 256MB RAM . A Tualatin 1.4GHz 512KB and a Geforce 3 Original OC to TI 500 with a Voodoo 2 12MB. I am currently playing The Godfather on it. All the setting are set to low as its a 2006 game. I am actually really enjoying it 😀
Reply 33 of 42, by Jo22
GemCookie wrote on 2025-08-14, 09:25:
It does, but memory managment of Windows 98SE is on a different level.
More information:
https://web.archive.org/web/20040410084807/ht … 4/a/memmgmt.php
"Memory management in Windows 98 and Windows Millennium Edition (WinME) is dramatically improved over what existed in Windows 95.
It is so much improved that, for nearly everyone, nearly all the time, the best recommendations on how best to optimize memory usage in Win98 is: Let Windows handle it."
https://www.informationweek.com/software-serv … ows-98-winalign
InfoWorld - Windows 98's WinAlign will load Microsoft apps more quickly
Edit: A copy of the batch file for walign can be found at wayback machine:
https://web.archive.org/web/20210505023848/ht … les/WMALIGN.ZIP
Reply 34 of 42, by AncapDude
Interesting article on memory management. Thanks.
Reply 35 of 42, by GemCookie
Jo22 wrote on 2025-08-14, 10:32:
It does, but memory managment of Windows 98SE is on a different level. […]
More information:
The VCache bug described in the article sounds like a side effect of a common controls library update. As for WinAlign, the performance figures for it are seemingly lost to the sands of time. If I find a few hours to spare, I'll test both operating systems on my K6-2 build.
Reply 36 of 42, by ppgrainbow
For anything Pentium and Pentium MMX, I'd go for Windows 95 if the size of the hard drive that I install it on is large enough. And if I have enough RAM installed, I'd go for either Windows NT 3.51 or Windows NT 4.0 for increased stability.
For 486-based PCs, I'd go for Windows 3.0, Windows 3.1x or OS/2 2.x. 😀
Reply 37 of 42, by Jo22
ppgrainbow wrote on 2025-08-15, 22:26:
OS/2 Warp 3 might be less power/memory, actually. There's also a Connect version (WfW counterparts).
IBM was acting unusual for actually lowering requirements with some newer versions.
OS/2 2.0 is worst in terms of memory requirements, I think.
v2.11 has 32-Bit graphics drivers and Windows 3.1x compatibility. MMPM/2 is still optional installation, I think.
Edit: There's also Warp 4.x, of course, which ships with more drivers.
But I often think that Warp 4 is like the answer to Windows NT 4.
A fast 486 or Pentium is probably recommended.
Reply 38 of 42, by ppgrainbow
OS/2 2.0, 2.1, 2.11 and 2.11 SMP can all perform well if 64 MB or more RAM is installed. 😀
In OS/2 2.0, Windows 3.0 only supported Standard and Real Mode and can address up to 64 MB of memory in the subsystem. For OS/2 2.1 and up, Windows 3.1x supported Standard and 386 Enhanced Mode and is capable of addressing up to 128 MB of memory in the subsystem.
Reply 39 of 42, by Jo22
ppgrainbow wrote on 2025-08-16, 08:14:
+1
There's a commercial/training video about OS/2 v2:
https://www.youtube.com/playlist?list=PLC5zoB … GGf3jFOAYV87R_u
In essence, OS/2 was initially implementing the whole Windows memory-managment within Win-OS/2.
But beginning with Windows 3.1 it patched existing Windows to become an DPMI client.
That's very interesting, because it removed need for XMS/Himem.sys.
Memory now could be accessed from Protected-Mode and with better performance.
In principle, Win-OS/2 would have had offered better performance to
demanding Windows applications that juggled with lots of data.
Provided, that OS/2 itself have had enough physical RAM available.
