First post, by Bizz
I couldn’t believe my luck, I found a Voodoo2 in a trash pile at the local recycling depot. It’s an 8MB Diamond build and I’m on my native voyage build with it.
Build specs:
- Mother board - VX97 (with custom BIOS)
- AMD K62 500mhz
- 16mb RAM
- ISA Sound Blaster CT4180
Now, the hiccup:
- S3 ViRGE
- Voodoo2
They are physically impacted by the heatsink of the CPU.
There is some bend and sway in the cards both above and below the CPU; the Voodoo2 is above and S3 below. No electrical connection, but the voodoo2 has a couple of RAM chips against the CPU.
Is this a bad idea?
