First post, by aspiringnobody
aspiringnobody
Offline
Hello guys/gals -
I've made a 3D printable mount for a 40mm fan on the heatsink of the Voodoo 3 2000 (and likely any other heatsink that measures 40x40x7). Find the files on printables here. I recommend that you print from ABS or at a minimum PETG. PETG will likely be right at the limit though, my V3 gets very hot!
- AN
