First post, by Retroplayer
I picked up a Hammerhead P233 tablet recently and I am in the beginning stages of restoration/modification.
The base features are:
Pentium 233mhz
64MB RAM
20GB IDE HDD (must have been replaced at some point, stock is supposed to be 3.2GB or 6.4GB)
9.5" transflective monochrome LCD VGA resolution
Wacom digitizer (from Pen Computing Magazine, this is apparently a proximity-sensing electromagnetic type)
2 Type II PCMCIA slots
Infrared com port on rear
7.2V NIMH battery (dead)
12V center polarity DC jack for charging/power (I assume about 3A) Works with my 5.5x2.5 adapter
There is a 50 pin dock connector on the rear which looks something like a mini centronics style. Trying to determine what the mating connector is.
Found a Reddit thread that provided a pinout
The 20GB HDD was not working in the tablet. Will need to see if it is truly dead. Hoping that I can at least get drivers and utilities out of it before full death
NIMH battery is dead, should be possibly to rebuild
It is going to be pretty useless without at least a keyboard. Getting the parts to wire in a PS2 port until I can figure out the docking connector part number
Hard drive will be replace with a CF card
3 com ports appear to be available on the docking connector. COM1 has all signals and the other two only RX and TX. Full parallel port, VGA, and audio outputs also available.
The rubber housing is beginning to get a little sticky. I may get plastidip spray and apply a couple of coats to seal and resurface it.
This is certainly one of those projects where you ask yourself if the effort is worth it, but the specs hit that sweet spot for me. It has that look and chunkiness that makes it look 80s even though it appears to have been made in 2000.
I wanted to post about it here in the hopes that others have experience with this model and also to gather the data in one place for those searching for information in the future.
I am attaching the docking connector information for now.
The mating connector part number is : 3M 10150
These two part numbers are the solder cup version of the connector and the cable hood:
10150-3000PE - Solder cup connector
10350-52A0-008 - Cable Hood
Pen Computing Magazine review:
http://pencomputing.com/archive/PCM27/Hardwar … /walkabout.html
Reddit thread with some external and internal pictures:
https://www.reddit.com/r/vintagecomputing/com … _was_the_worst/
Anyone here have any experience with these?
Reply 1 of 16, by BitWrangler
Not familiar with these ones, but I've dipped toes into the weirdness of pen computers from time to time, so I'll throw in a hint when I can.
I would tend to assume that the BIOS is only going to like up to ~8GB HDD in this, due to it's era, and if the 20GB can be got going it's likely to need overlay software to use all of it.
As it is vehicle mount also, some of the sites about fixing up old police and emergency vehicles may have info. There was one machine I went down a rabbithole with that that was where I was getting the best info.
Reply 2 of 16, by Retroplayer
Great tips! Yes, it is possible that someone installed the 20GB HDD expecting it to simply work.
Step 1 is getting a PS2 keyboard wired in as I will not have access to the BIOS or anything else without it.
I found a vehicle mount for the Hammerhead that looks like the same connector and screw post positions. It is just a pass through (brings the docking connector to another point) but it will be a source of the connector and I might get lucky and it will have some breakout points to rig up my own dock.
Reply 3 of 16, by Retroplayer
You made the correct call about the 8GB limit. I managed to get the drive to read with a USB adapter and found that it was partitioned to 8GB.
Thankfully, it appears that I was able to pull the data, but scandisk found about 7mb of broken file chains. Hopefully just windows stuff and not the rare stuff.
Reply 4 of 16, by Retroplayer
I finally received the vehicle mount and it has a PS2 connector which I couldn't see from the auction photos. The docking connector is also a nice ribbon cable with 2.54mm headers which makes it convenient for making my own dock.
But the big reveal is that now I know what the mating connector part number is: 3M 10150
These two part numbers are the solder cup version of the connector and the cable hood: 10150-3000PE & 10350-52A0-008 ($14 from China.)
Reply 5 of 16, by BitWrangler
Well that should make things easier, sweet.
Reply 6 of 16, by Retroplayer
Couple of things now that I can get into the BIOS setup:
1. This model does have USB. It is High Speed according to the bios. The vehicle mount has a USB port as well.
2. There is something more involved with my HDD issue.
The HDD that was installed worked in my USB reader. I tried it again and the tablet did not recognize a hard drive. I swapped in a compactflash-IDE drive and it does not see that either.
I am waiting on a PCMCIA floppy drive to arrive, so I have no options for booting at the moment.
I found a stylus which will be coming this week.
If I need to work on the mainboard, I am going to need to add a VGA connector to the dock because you really can't get to it with the LCD attached.
It is not clear from the BIOS if it is possible to boot from a USB stick. I might give that a try later today when I have some free time. If not, I am going to have to put it aside again until more parts arrive.
Reply 7 of 16, by BitWrangler
Did it like a regular stick? Gut feeling is it's gonna want under 8GB on a USB stick and legacy USB boot modes tend to be specific, have to set USB HDD, which a stick of an acceptable size to HDD support in the BIOS will usually work with, USB CDROM, which is actual external CDROM on USB, or USB Floppy, which can be a real drive. However, Rufus and maybe some other utils can format a USB stick to a USB floppy format, which some motherboards needed for BIOS bootblock recovery. Might need a 2GB or smaller stick for it. Now with a "floppy boot partition" on the drive, because floppies use FAT12, you can get it up to the max size for FAT12 which is 32Mb, which is a bit more useful than 1.44, but gets you a bit more space for troubleshooting utils and stuff to sort it out to boot by itself.
Reply 8 of 16, by Retroplayer
I actually haven't gotten back to this one yet. I got derailed working on the Libretto 20CT. You are probably right about the USB. It may even be specifically limited. The BIOS mentioned "Full speed" so it is very likely just USB 1.0. Originally it also had Windows 95.
But it is better than not having USB at all.
I actually have some period flash drives somewhere (like 128MB) "pendrives".
Reply 9 of 16, by Retroplayer
Another one popped up cheap on eBay, so I have a second one on the way. Hopefully I will end up with two, but this will at least ensure I end up with one.
I wrote some code to interface with a webtv infrared keyboard to act as a receiver converted to PS2. My plan is to embed this into the tablet so I will always have a wireless keyboard without needing anything strapped to the docking connector.
Reply 10 of 16, by Retroplayer
Sweet. The second tablet works. The battery was preventing it from turning on. After removing the battery, I was able to power it up.
I had to power cycle a few times to get the hard drive to spin up, but then Windows 95 booted.
I still plan to get the first one working again of course, but it is nice to have one fully working to use for a reference. I will likely replace the HDD and rebuild the batteries. The pack appears to be 5 AA NIMH (7.2V)
Now I just need to figure out what battery is used in the stylus.
EDIT: It appears to be an AAAA battery
Reply 11 of 16, by BitWrangler
Bust open an energiser 9v PP3 and there's 6 near as dammit AAAAs in there, they might be just a little short and you need a washer or something to pad them, if there isn't enough reach in the spring contact.
Edit: BTW that seems to be true of most Alkaline 9Vs only. The zinc dry cell ones will have a pile of carbon blocks, the NiCads are variable, maybe have stack of button cells.
Reply 12 of 16, by Retroplayer
BitWrangler wrote on 2025-09-26, 13:19:
I had read that after I had already ordered them from Amazon. They were cheap, though.
Well, I got them today and just tried it. This stylus apparently doesn't work with the P233. It was advertised for the HH3, but I thought I had read somewhere it was supposed to be compatible with the P233 as well. Guess not.
I am not sure what stylus to purchase now. Early info I found said it was a wacom tablet, but I am not seeing any wacom branded software on the tablet.
Reply 13 of 16, by BitWrangler
Got anything around with a resistive stylus? Palm, Newton, Axim, Ipaq, or other winCE. Could try that, though corner of a fingernail usually activates it well enough. Would guess that most basic type would be resistive grid doing mouse emulation.
I am racking my brains for a name though, someone Wacom had taken over middling late 90s, could be their tech.
Reply 14 of 16, by Retroplayer
From Pen Computing magazine:
"The Hammerhead P233 uses a proximity-sensing electromagnetic Wacom digitizer using a battery-less inductive pen."
Reply 15 of 16, by Retroplayer
I just found a cheap Wacom tablet with stylus from around the same time period. I don't really know any other way of figuring out what it is. Crossing my fingers.
Reply 16 of 16, by Retroplayer
Strike 2. The old Wacom tablet pen doesn't work with the tablet either.
