First post, by noshutdown
the concept "best" means high pixel clock, sharp analog output with accurate colors and brightness.
there was the ibm 37rgb528, and the texas tvp3026, and others?
i think nvidia made their domestic external ramdac chip for use with the gtx280 and probably some other modern 3d cards, not sure about ati.
Reply 1 of 4, by dominusprog
I believe Edsun was one of the higher end DACs along with the Sierra. But the Samsung 66MHz (KDA0476CN-66) on my Trident 8900C producing very sharp and clean image.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by The Serpent Rider
Nvdia NVIO2 chip is probably the most advanced, but it's not a simple RAMDAC, but an input/output device, so it also has functionality of chips like Rage Theater.
Reply 3 of 4, by noshutdown
are there other nominations? especially those high end cards before everyone have ramdac integrated?
Reply 4 of 4, by asdf53
One that stood out for me was a Western Digital WD90C30-LR (RAMDAC: Winbond W82C487P-80). I didn't use it a lot, but noted that it had the brightest, most saturated output of all cards. I measured an output voltage of 548 mV on the RGB channels, which might even be slightly overdriven. Sharpness I could not test because the card has only 512 KB RAM.
I have one card with a TI TVP3026 and it has disappointing brightness, did not use the card because of this. One card with a Brooktree BT485AKPJ135 had fantastic brightness, but slightly washed out colors.
