First post, by cansting
I'm looking for an OPL3 ISA sound card and found this one:
Addonics Sound Vision 500 A151-830 Yamaha OPL3-SA YMF701
Before I buy it, does anyone have any comments about it? My intention is to use it purely in DOS and have it disabled in Windows (having Aureal Vortex for that). Does it require any drivers for dos to work, and if it does, are they generic opl3 drivers or rather model specific (if yes, cant find them anywhere)
Thanks!
Win98:
InWin A500 with Asus P2B, Pentium II 450, 512MB PC100, Creative 3D Blaster Annihilator Pro +Diamond Monster 3D II, YMF719E-S+ Diamond Monster Sound MX300
Win XP
Deepcool Tesseract with D875PBZ, P4 3.0 prescott, 3GB DDR400, HIS HD4670 iceq
Reply 1 of 4, by dionb
DOS doesn't do 'drivers', software talks directly to hardware, there's no driver layer in between. There is definitely no such thing as an OPL3 driver, software just writes to 0x388.
However this is a PnP card, so it needs to be initialized, and you generally want to set the mixer.
The original Yamaha software is SETUPSA.EXE, which sort of does the job.
Unisound works to init the card, but doesn't do anything with the mixer.
Probably the best option is fellow Vogon Tiido's modified initializer: SETYMF.EXE
You can find the latter here: https://vogonsdrivers.com/getfile.php?fileid= … menustate=69,52
As for the hardware: a lot of YMF719-based cards have pretty cheap/crappy build quality. If you're lucky that won't be a problem, if not you could have noise issues.[s/]
The above applies to YMF719 cards, as pointed out, this is a YMF701 card. I need better glasses.
Reply 2 of 4, by Grzyb
dionb wrote on 2025-08-26, 14:56:
Unisound does have mixer options.
Do you mean they don't work for that Yamaha chip?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 4, by Thermalwrong
DOS doesn't do 'drivers', software talks directly to hardware, there's no driver layer in between. There is definitely no such t […]
“Um ackshually..." 😁
The SV500 is a weird one! It's a YMF701C and is not a true PnP card so Windows won't detect it and nor will Unisound, but SETUPSA will initialise it to allow it to work. Here's my experience with it: Re: Bought these (retro) hardware today
Once it's initialised it a great SB Pro clone card like the later YMF715/718/719 chips and because it's not PnP it won't conflict with another soundcard if setupsa isn't run to initialise it.
Reply 4 of 4, by dionb
Thermalwrong wrote on 2025-08-27, 13:32:
“Um ackshually..." :D […]
I stand corrected.
