First post, by DustyShinigami
Yet more issues present themselves... Totally overlooked this at the time of buying this motherboard - https://theretroweb.com/motherboards/s/abit-ab-be6-ii#chips - but it turns out it has no onboard audio capability. >_< Very peculiar considering the micro version does. This is a full ATX board. This is a bit of a problem considering before, I was daisy-chaining my onboard audio with my ISA sound card for games that use redbook audio. My question now is - can I daisy-chain a PCI sound card with the ISA card for the benefit of redbook audio games? And if so, what are people's recommendations?
As a seperate issue, I don't appear to be getting audio at all from my speakers since getting this mobo up and running. As far as I'm aware, everything was plugged and set up from when I last used it. The ISA bank must be working fine because the PC recognises the sound card. I've tried plugging the audio jack into each of the sound card's outputs, but nothing. Volume dials are turned up, plugs are plugged in... Not sure if there's something silly I'm overlooking, or I've done, or if there's another underlying issue.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 1 of 14, by DustyShinigami
I know others have mentioned there's no successful way of getting CD images to work with redbook audio, but someone pointed me to the PicoGUS. Has anyone got/used one?
https://hackaday.com/2025/07/19/picogus-adds- … ion-to-isa-bus/
OS: Windows 98 SE
Reply 3 of 14, by DustyShinigami
furan wrote on 2025-08-26, 15:52:
Great. Thanks for sharing. I'll have a read through it. Will have to invest in one at some point. 😀
OS: Windows 98 SE
Reply 4 of 14, by DustyShinigami
I've returned! :p So from what I've been told the Pico isn't very good under Windows 98...? I'll probably still look at getting one for the extra customisation and for DOS games, but for digital audio under Windows, I think I need a decent PCI sound card. So I could do with some recommendations on what to go for. 😀
OS: Windows 98 SE
Reply 5 of 14, by dionb
Well, apart from daisy-chaining the ISA card (I'd personally use a mixer instead...) what does it need to do?
The usual recommendations are Aureal 8830 if you like their style of 3D audio, otherwise SBLive-Audigy if you like EAX (and don't have a Via 686B southbridge), but if you just want good SNR and/or digital audio, an M-Audio 2496 is hard to beat.
Reply 6 of 14, by DustyShinigami
dionb wrote on 2025-10-05, 15:09:
A mixer? I think someone mentioned a mixer once before, but I think it was quite pricey.
All it needs to do is allow me to toggle between digital (WDM) and VxD. VxD for any games that I play through DOS and combined with my sound canvas and WDM for the later released titles that make use of Redbook Audio. Nothing fancy. 😀
I don't have much, if any, experience with audio styles and EAX and the like. So I don't really have a preference. I have come across SBLive Audigy a few times in discussions.
OS: Windows 98 SE
Reply 7 of 14, by DustyShinigami
I've seen some Audigy cards listed with a head unit. Are these worth picking up? Are these considered mixers?
OS: Windows 98 SE
Reply 8 of 14, by dionb
No, that's just a bunch of extra ports and/or extension of existing ports to the front of the machine. You're still daisychaining through a sound card, with potential for more noise, and dependence on software volume control.
Mixers don't have to be hugely expensive, although you generally get what you pay for and can go crazy. I have two Behringer RX1602 16 input (8 stereo) mixers with most of my vintage PCs hooked up. But you can get a simple 2-input mixer for a lot less, and inevitably there's a thread here somewhere (can't find it) of one that fits in a PC slot.
Reply 9 of 14, by DustyShinigami
dionb wrote on 2025-10-06, 19:18:
Ahh, I see. Thanks for clarifying. 😀 At this stage I can't say I'm too fussed about a mixer. Space will probably be an issue, too. Unless it was to go on top of my SC-55.
OS: Windows 98 SE
Reply 10 of 14, by DustyShinigami
Also, I've just ordered myself a Creative Sound Blaster Audigy Player 2 5.1 SB0240. 😀 Now to track down the drivers...
OS: Windows 98 SE
Reply 11 of 14, by DustyShinigami
It's quite possible I'll need to find something else as an alternative to the Sound Blaster Audigy 2. I'm not sure I'm going to be able to get it working and it makes me anxious about getting anything else from Creative if they're finnicky to get working. 🙁
OS: Windows 98 SE
Reply 12 of 14, by dionb
Creative SBLIve cards (incl Audigy) are pretty demanding of the PCI bus, but the only compatibility issue is with the Via 686B southbridge. Your BE6-II has an Intel i440BX chipset and is fine. Only other issue is that SBLive cards refuse to share PCI interrupts. There are four on the PCI bus, your motherboard has five slots and AGP and onboard IDE also use interrupts, so you probably only have one or two slots that are not shared. Slots 3 or 4 are usually best bets, but check the manual to be sure.
Reply 13 of 14, by DustyShinigami
dionb wrote on 2025-10-12, 20:58:
Thanks for the insight. I have a couple of things to try, which I'm hoping work, or at least put the PC back to working order. I did try putting it in each PCI slot, but the results were the same. I'm kind of powerless to try various things at the moment as the PC doesn't boot properly. Hardly any devices load/work. It's almost like Safe Mode, but worse. ^^
OS: Windows 98 SE
Reply 14 of 14, by DustyShinigami
Wondering if I'll be safer with an older Sound Blaster card. The one I have is from 2002/3 and I just can't get it to work. But if I get one from the mid 90s, it still needs to be something that supports digital audio/WDM drivers. Perhaps a Sound Blaster Live...?
OS: Windows 98 SE
