I need Pentium 4 experience.
First post, by tarik
Hello friends, my question is as follows. I have a Pentium III system with a Voodoo3 3000 running Windows 98. In addition, I have an E6600 with an ATI FireGL X3 AGP running Windows XP. I actively use both of these machines and they work well. Now my question is that I want to install Windows Me on a Pentium 4. I have an ASUS Socket 478 motherboard with an Intel chipset that supports dual channel. My processors are:
P4 3 GHz 1 MB cache 800
P4 2.4 GHz 1 MB cache 533
P4 2.4 GHz 512 KB cache 533
My goal is to build a low-power system, so I won’t be using high-end graphics cards. I have cadrs;
FX5500 128-bit
FX5600 128-bit
FX5700 128-bit
GF4 MX440 128-bit
Radeon 9550
9600XT
9600Pro
9800Pro
Which setup would you build for my Pentium 4 and Windows Me system? My goal is gaming, mostly games from 1998 to 2002. Thanks for your help.
Pentium 3 1000mhz, 512 mb sdr, voodoo3 3ooo win98
Pentium 4 2400 mhz, 512 mb ddr, geforce4 ti 4200 winMe
Pentium E6700, 2gb ddr2, Ati FireGL x3 AGP winXP
Reply 1 of 29, by chinny22
I don't really do low power systems so this goes against my way of thinking, but
Any P4 would be a powerhouse for a WinME system. so you could go with whichever has the lowest power consumption but it's not like the fastest will cause any compatibility issues so that's what I would choose myself.
Out of your list of Graphics cards I'd go with Nvidia just because they typically have better compatibility. Again I see no point going slower for what would be marginal power savings.
And faster cards will allow you enable higher resolutions or driver enhancements like AA
Reply 2 of 29, by AncapDude
tarik wrote on 2025-08-26, 23:13:
478 is the worst platform you can choose for this purpose. You are better off with a 370 or 775 Core2 CPU for this. Anyway i would look into the listings of cpu world for low TDP and pick one of that. It may be a celeron though. If i were required to pick from your list, i would choose the 3GHz CPU and the Radeon 9600 Pro.
Reply 3 of 29, by dionb
Second that. Look for a Pentium M So479 motherboard if you want a low-power system from similar era with similar performance.
P4 CPUs have a TDP similar to modern mid- to high end CPUs, but with far less power management. They basically run hot all the time they're on.
If "low" power is the main criterion, you have two Prescott CPUs and one Northwood in the list. Prescott runs hotter than Northwood at same speed & performance, so the 2.4GHz Northwood (512kB cache) would be the least excessively hot of the three. Pentium M CPUs have about 50% more IPC (i.e. are about 50% faster for a given clock speed) than Pentium 4, so a 2GHz Pentium M would be equivalent to a 3GHz P4, but at a TDP of 21W instead of 59W (for the 2.4GHz Northwood) to 89W (3GHz Prescott)
For GPUs it's a similar story - the R9800Pro is definitely the fastest of the lot but also the hottest. Probably the 9600Pro gives you best performance per Watt.
Reply 4 of 29, by tarik
chinny22 wrote on 2025-08-27, 01:16:
I don't really do low power systems so this goes against my way of thinking, but […]
The reason I want low power consumption is because it produces less heat and lasts longer.
Reply 5 of 29, by tarik
AncapDude wrote on 2025-08-27, 02:14:
I already have a Pentium 3 and Voodoo 3 system for that purpose. This one is a different system. I want a powerful CPU, but a low-power and reliable graphics card so it won’t break. Actually, the system I want is quite clear—maybe I just didn’t explain it well. In general, powerful graphics cards tend to fail, but CPUs and motherboards are much more durable and easier to repair. That’s why I want an older operating system with a strong CPU for 1998–2002 games. For this, I need the coolest-running graphics card possible.
Reply 6 of 29, by PD2JK
Then go with the MX440, some of them are passively cooled. Make sure there is airflow though.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 7 of 29, by tarik
I have examined the benchmark tests of the Intel Pentium E6700 CPU, and it’s a processor that everyone seems to overlook. Its single-core performance is surprisingly fast. Link: https://www.cpubenchmark.net/cpu.php?cpu=Inte … 3.20GHz&id=1106
This system of mine has Windows XP installed, and with my ATI FireGL X3 256 MB AGP card—which Phil tested in his video—it’s incredibly powerful and the driver support works perfectly. What I mean is, I already have a DOS, Glide, or high-performance XP system. What I’m currently working on is building the coolest-running PC possible for Windows ME and games from 1998–2002. Maybe now I’ve explained myself better. 😀
Reply 8 of 29, by zyga64
For cool low-power P4 I would go with Cedar Mill. Its 'D0' stepping has a TDP of only 65 W.
But they are only available in the S775 version, and you already have a motherboard (s478) and several processors to choose from.
So it's not an option anyway...
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 9 of 29, by The Serpent Rider
I recommend choosing Athlon XP experience with a motherboard that can undervolt CPUs.
Reply 10 of 29, by Living
tarik wrote on 2025-08-27, 10:59:
then go for a Sempron 754.
Reply 11 of 29, by Archer57
I understand what you are saying in general, but IMO what you are trying to do makes very little sense.
If you want as reliable and low power as possible you have to go as new as possible. Everything P4/S478 is about as bad for what you want as it gets - hot and within the time of multiple widely known hardware defects, like capacitor plague.
In a sense the system you already have, E6700+X800 based one, should be good for what you want - late 98/early XP. You should be able to run 9x on it and it will be much better than anything P4/S478. By the way it is not nearly powerful enough to be "high-performance XP system", that would be something much later like LGA1155+GTX6xx/GTX7xx. As good as X800 is for its time it will not run crysis...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 12 of 29, by tarik
Archer57 wrote on 2025-08-27, 13:03:
You’re right, calling it high performance would be an exaggeration. What I actually meant was that within the AGP era, a card based on the X800 could be considered “high” for that time—of course, not counting the GeForce 6 series. I don’t think undervolting would make much of a difference on a Pentium 4. I don’t have an Athlon system either. So, with what I currently have, I think the most reasonable choice is the Pentium 4 2.4 GHz with 512 KB cache and a 533 MHz bus, the 65-watt version. I could install Windows ME along with Windows 2000.
I really like the E6700 AGP-slot machine, because it has the old AGP slot while still being much closer to modern systems. Also, it’s actually one of the best single-core performers, but since people often make judgments without looking at test results, it tends to be overlooked.
Reply 13 of 29, by Matth79
Low power and P4 don't go together, looks like the 512k 2.4 is a Northwood which has a significantly lower TDP than the Prescott - and the 3.0GHz 800FSB would seem to be a P4 HT - and while the HT won't be useful for a single threaded OS, it actually has a slightly lower TDP than the 2.4 Prescott.
Also, probably worth using an idle cooler such as RAIN to force the CPU into a low power state when idling
Reply 14 of 29, by tarik
Matth79 wrote on 2025-08-27, 13:52:
I’ve seen that the Pentium 4 3.0 GHz (1 MB cache, 800 MHz FSB) is rated at 89W TDP, while the Pentium 4 2.4 GHz (512 KB cache, 533 MHz FSB) is listed at 65W TDP. Among the three CPUs I mentioned earlier, it’s really confusing to determine which one actually has the lowest power consumption.
Reply 15 of 29, by Shponglefan
I'll echo some of the other comments here that trying to build a low power system based on the Pentium 4 platform is a bit contradictory, especially when including Prescott based Pentium 4 CPUs as options.
For Pentium 4 , a slower Northwood processor like the 2GHz models have TDP of about 52-54W.
A better option would be ditching the P4 platform and going with a mobile Athlon XP or Sempron build.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 16 of 29, by tarik
Shponglefan wrote on 2025-08-27, 14:29:
How many watts of power do these processors actually consume?
Reply 17 of 29, by RetroPCCupboard
tarik wrote on 2025-08-27, 15:39:
Is your goal actually low power (as I think any P4 build is low power compared to modern gaming PCs), or is it that you just want a quiet system?
If the latter, I'd be inclined to just replace stock fans with something like Noctua, and use a modern PSU that stops the fan under low loads
Reply 18 of 29, by tarik
Graphics Card Idle Power Load Power TDP Total System Idle Total System Load
GeForce4 MX 440 128-bit 10–15 W 25–30 W ~30 W 40–50 W 85–95 W
GeForce FX 5500 128-bit 15 W 30–35 W ~35 W 45–50 W 90–100 W
GeForce FX 5600 128-bit 15–20 W 35–40 W ~40 W 45–55 W 95–105 W
GeForce FX 5700 128-bit 20 W 45 W ~45 W 50–55 W 105–110 W
Radeon 9550 128-bit 15 W 30 W ~30 W 45–50 W 90–95 W
Radeon 9600 Pro 128-bit 20 W 40–45 W ~45 W 50–55 W 100–110 W
Radeon 9600 XT 128-bit 25 W 50 W ~50 W 55–60 W 105–115 W
Radeon 9800 Pro 128-bit 25 W 55 W ~55 W 55–60 W 115–120 W
Reply 19 of 29, by tarik
RetroPCCupboard wrote on 2025-08-27, 15:45:
I want both silence and longevity in terms of heat. The main goal is actually to build a system for games from the 1998–2002 era.
