Ta, I was hoping someone would reply with sugestions!
I remember at uni ( along time ago!) the electronics dept where i was studying had a whole lab of 386 (sx 25MHz I think) machines with 4MByte of RAM & no hard drives -everything over 10Mbit Ethernet - I gave up trying to browse the web (pretty early days for the www...) on those!
It does feel like something isnt right, I was expecting the transfer rates to be a bit higher. I had a quick play with MTU etc in Trumpet winsock, but I'll have  another go now you've said that. At one point I did notice one picture stoped after only about 90% of it was loaded, it did feel like it had stopped after so many re-tries somewhere along the line, or something similar.
The website Ive been using is very undemanding, 50KByte of html & a 55KB jpeg, the next page I use is more demanding, 145KB or so of html & 51 jpegs, mostly between 9KB and 20KB a couple over that.
Even though Im moaning about the speed, I did still spend a while browsing that site, it wasnt sooo bad...
But even just accessing windows shares over the network seems a little slower than I thought it should be, I mean even a 386 can handle TCP/IP over a network adapter at decent rates, so surely it cant be the processor struggling with TCP/IP.... so 6KB/S seems a bit poor for a 115200 baud rate link, unless the overhead is much higher than I thought?
Another ref to save others trying this some time: I tried a Win95 update, an windows unoficial update pack (ok, maybe asking for trouble!) to update to newer versions of the dial up modem & Winsock. Id be wary of this! The bloat from the updates slowed win 95 to a crawl (much higher use of swap file, even just after boot), but the modem/dial  up adapter updates broke the dial up that I was using: the null modem definitions Im using still go through the pantomime of dialing up, even though there is no modem, but it seems to get through this OK, perhaps just ignoring what happens with phoone dialing & trying to connect anyway.... With the updates I had to re-install the modem and then it just complains that the modem doesnt respond...
I suppose I could try sending the esp-12 some AT commands via hyperterminal to see how it handles them, but I am using the slip version of the software for it, not the modem software.... But its a very long time since Ive used AT commands!!! Id have to brush up on those!
Fortunatley I took an image of the compact flash before updating & Ive reverted to that!
