First post, by OzzFan
Hello all,
I've tried searching the forums for an answer, so apologies if this has been covered already. I have driver disks for the Diamond Multimedia Stealth64 and the SpeedStar, however when I load the drivers for Windows 3.1x, the InControls tools tell me that my monitors.ini file is "corrupted." I remember back in the day I had to download a fixed monitors.ini file but I no longer have it.
Does anyone else know where to find the corrected file? Or how to manually edit the .ini file to fix the issue?
Thanks!
Hobbyist Developer : https://www.shelteringoak.com/du/
