Socket AM2 Build Ideas
Reply 20 of 47, by stinkydiver
Update: Noctua Nh-U12s has arrived, and the cpu runs in the low 20s at idle 😀
I've had a bit of of a mission getting this board working. Initially I was getting a USB over loaded error at boot, with the system having a count down timer and then powering itself off. After replacing the cmos battery and clearing the cmos the system would boot, but only with one of my two Corsair XMS sticks. Then eventually it wouldn't POST at all, and I found moving the single stick from slot A1 to A2 the system would post again, and then after a swapping the stick with the other and back again, the system wouldn't post at all! No stick in any slot would POST.
Thankfully I had a couple of 667 5-5-5-12 512MB sticks and the system boots without any issue (and in dual channel mode I might add)
Bit of a disappointment that the XMS sticks are not working...
I've also run into the dreaded AHCI install issue with Windows XP (a first for me), so currently trying to figure out how to get XP installed with a Nforce570 chipset on a SATA SSD. There is no option in the bios to set SATA to legacy mode. I've attempted to use WinSetupFromUSB but after the boot loader installs the nvata.sys drivers and entering text mode the system just sits at "Setup is inspecting your hardware configuration"...
Take that there and put it in here
Reply 21 of 47, by Archer57
stinkydiver wrote on 2025-08-23, 08:28:
Seen this issue a lot with s939 asus boards i've used for recent build. If anyhing goes wrong, like memory has issues, they like to throw whole "usb overcurrent" thing. Asus really screwed this up...
One silly way i always do it is to use IDE-SATA adapter, install windows, install SATA drivers, move SSD to SATA. Though it is weird there is no IDE/AHCI switch in BIOS, this hardware should be by far old enough...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 22 of 47, by stinkydiver
I've ordered a 2GB Kit (2x1GB) Kingston HyperX DDR2-800 PC2-6400U 4-4-4-12@2V KHX6400D2LLK2/2G for around $8 USD
Kingston appear to be in the approved vendor list in the motherboard manual (unlike Corsair). Fingers crossed these work.
As for a SATA to IDE adaptor, I do have one somewhere but can't seem to find it. So for the time being I am going to install Windows XP on a SD card via an IDE to SD adaptor.
Reply 23 of 47, by Raldsen
stinkydiver wrote on 2025-08-24, 00:56:
I had that bug too on my Asus nForce 4 board with SATA ssd's, I got a new WD5000AZLX instead and combined that with a cheap m.2 PNY NVMe SDD and got no troubles since. Both WinXP and Tiny8.1 still boot very fast of a modern hdd.
Reply 24 of 47, by stinkydiver
I had the system running OK on some spinning rust, after installing XP on the SD card, the system does lock up a bit when doing file transfer operations (I assume DMA issues, i've had this before when using this adaptor, and I've set the primary IDE interface to PIO mode in windows but the issues persist)
Uninstalling the Nvidia IDE drivers and it seems the same. Guess I gotta hunt down that IDE to SATA adaptor
Reply 25 of 47, by AlexZ
Check if you have warning for eventId 129 (Reset to device was issued) in event viewer.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 26 of 47, by stinkydiver
I managed to find my Sata to IDE adaptor
I installed Windows XP, then the nforce chipset drivers, shutdown and connected the drive to the SATA port and rebooted. System came up and all is well 😀
Reply 27 of 47, by stinkydiver
3d mark 2006 breakdown, 1024x768, Athlon 64 X2 6000+ (Windsor), GeForce GTS 250 1GB, 1GB Samsung DDR2 @ 667 5-5-5-15
Return To Proxycon - 39fps
Firefly Forest - 41fps
Slightly lower than what AlexZ got in his results for a similar setup in the Any love for AM2? Thread:
Return To Proxycon - 42fps
Firefly Forest - 43fps
I wonder if I will see an improvement with the ram upgrade when it arrives.
Reply 28 of 47, by matze79
That's nice, just be aware that the chipset is very likely affected by bumpgate and may die at any moment. At least ensure good cooling. I'd probably replace the heatsink with something of decent size with a fan because this whole heatpipe thing which couples chipset to VRM is just silly.
we had this too, i made a aluminium plate i put beneath the motherboard and chipset cooler with some isolation and used two screws with nuts and "clamped it"
works up to today.
The M2N is also affected by Capacitor Pest
Reply 29 of 47, by AlexZ
stinkydiver wrote on 2025-08-24, 07:33:
It is possible to get slightly higher score if you play with memory controller divisor and run memory at higher clock than DDR2 800. I did it in the thread. I would do it only in case you manage to find DDR2 1066 though.
Reply 30 of 47, by stinkydiver
matze79 wrote on 2025-08-24, 07:50:
we had this too, i made a aluminium plate i put beneath the motherboard and chipset cooler with some isolation and used two scr […]
works up to today.
Once I get it in a suitable case I will ensure good airflow, and I won't be using the computer for long sessions or super frequently, so I suspect it should last a good while without any mods. Since the motherboard is brand new the capacitors all appear to be healthy in appearance.
Reply 31 of 47, by stinkydiver
Found a good looking affordable case, a Cooler Master MasterBox E500L which has an optical drive bay (I really want one of these for it to be period correct)
https://www.coolermaster.com/en-global/produc … /?tab=tech_spec
However the max cpu cooler hight for this case is 157mm and my NH-U12S is 158mm. That is only 1mm difference, what are my chances of getting this to fit I wonder...
There are two versions of the case, one with a flat glass side panel and the other has a metal cover with a "protruding square" on both sides of the case.. there only appears to be the one cpu cooler hight measurement for both versions of the case, but clearly the metal side panel version would fit a bigger cooler because of that protruding bump..
UPDATE: After checking the datasheet for the non window version it says "CPU Cooler Clearance 172mm", woopie 😀
Reply 32 of 47, by stinkydiver
FarCry Benchmarking Utility results:
https://www.guru3d.com/download/farcry-benchmarking-utility/
Resolution: 1024×768
Ultra quality option, Direct3D renderer
Level: Pier, demo: 1.tmd
Pixel shader: default model
Antialising: From System×16
Anisotropic filtering: From System×16
HDR: disabled
Geometry Instancing: disabled
Normal-maps compression: disabled
Score = 95.15 FPS (Run 1)
Score = 95.95 FPS (Run 2)
Average score = 95.55 FPS
Resolution: 1280×1024
HDR: disabled
Score = 93.78 FPS (Run 1)
Score = 94.13 FPS (Run 2)
Average score = 93.95 FPS'
Using HWinfo32 I can see my average GPU temp is 41c and max (so far) is 55c. CPU max is 33c with average is 24c. I'm pretty happy with those temps, though will be interesting to see how they increase once the system is installed in a case.
Reply 33 of 47, by AlexZ
Try Farcry 2 benchmark "Demo Ranch" and "Action Scene" in 1600x1200. You probably aren't going to be playing in 1024x768, that is Windows 98 resolution. Temperatures without case have little meaning.
Max cooler height 157mm is definitely very small.
I will be going either with Zalman Z9 U3 (should support at least 160mm coolers, https://www.newegg.com/zalman-atx-mid-tower-s … 82E16811235036R) or Cooler Master N500 - Mid Tower (162mm max cooler height, https://www.newegg.com/cooler-master-atx-mid- … N82E16811119280). CPU cooler is going to be Scythe Ninja 5 (155mm height) or alternatively SilentiumPC Fera 3 (155mm height). Noctua coolers tend to have a bigger height.
Reply 34 of 47, by Raldsen
Recently recapped the sibling of your motherboard the M2N-E, it came with a whopping 31 KZG caps and did some testing with some Corsair CMX2048-8500C5 sticks from 2009. This memory seems to work more than fine at 800MHz (750 because of 6000+ multi) @4-4-4-12 @ 1.95v, no stability issues or errors. Impressed with the stability of this early ASUS AM2 board. Strange that your Corsair isn't working, Corsair XMS was known to be compatible and recommended alot.
Reply 35 of 47, by AlexZ
How many of those 31 caps were bad?
Reply 36 of 47, by Raldsen
AlexZ wrote on 2025-08-30, 07:44:
Tested a couple. There where 5 visibly bulging caps one of which still measured as a "low" ESR cap, the other 4 completely dead, essentially becoming resistors. These 5 caps where also mostly in cooler areas around the memory slots and all 6.3v 820uF, you'd think the VRM caps would go bad first but these are all fine. All of the visibly fine ones also tested okay on the meter. So if the KZG looks fine it's more likely than not fine. Still better to remove them from the premises though, they have a habit of creating alot of FUD.
Reply 37 of 47, by stinkydiver
Raldsen wrote on 2025-08-30, 05:48:
My board posted with 1 Corsair stick initally when I started testing it, but subsequently refused to post a few tests later down the line with either sticks. Maybe the RAM is bad? Who knows... I don't have any other DDR2 boards to test them in.
Still waiting on some Kingston modules to arrive. For now it is working fine with 2 Samsung 667 modules.
I'm undecided on what case to put this build in, but I think I will be scrapping the ODD. The M2n-SLI Deluxe supports booting from USB, and my USB ODD also boots fine if need be. Any 2002-2006 games I will likely be playing via GOG, so I don't really see a point in trying to find a case with a 5.25 bay and a cooler support for my Noctua, as the case dimensions will end up huge, and a low physical footprint is more desirable.
Leaning towards the Jonsbo D-41, which is one of the smallest cases that support ATX I can find, and good looking/cheap aswell! https://www.jonsbo.com/en/products/D41MESHBlack.html
Reply 38 of 47, by stinkydiver
Kingston ram arrived, along with a case. Now to put it all together...
If I need to use an optical drive, Im thinking of picking up a Vantec NexStar DX2, which would look pretty cool as a external attached device. They are quite pricy though... so probably will just settle with my compact external drive for now..
Reply 39 of 47, by stinkydiver
Some pics of the build so far
I moved the GPU to the bottom PCIe x16 slot for better airflow, I'll think I'll add a couple of intake fans to help.
The ram is running at 752mhz so I might do some tweaking to get it running at 800mhz
3d Mark 06 score went from 11065 to 11513 after upgrading the ram.
