If it was working before you disassembled and cleaned it, chances are that
you moved something or didn't put it back together quite correctly.
Check that the heads are free moving and come close enough together to touch
when no disk is inserted.
If you have a DOS system, you can use my ImageDisk tool to do fairly detailed
analysis/debug of a drive. It has a "Align/Test" function which lets you
perform low-level/basic operations (like seek to track) and evaluate how well
it can read/write/format in more detail than the usual FDC commands.
- You can get ImageDisk at DavesOldComputers->Software/Images
Verify that it seeks correctly. Try track 0 and 79 which should move the head
to the outer/inner limit, and 39 which should near the middle (1/2 way).
Confirm that the head loads/unloads correctly - I often do this without
a disk and a thin strip of paper under the head from the side. When opon/unloaded
you should be able to move the paper strip side to side with little resistance,
when closed/loaded (ie: trying to read the non-existant disk, there should be
more resistance (don't force it to move, just confirm that it doesn't want to
like it did when unloaded).
How much did you disassemble it? Did you just take the cover off to
access the internals. or did you unscrew/remove parts for deep cleaing?
If you didn't remove/loosen the head or stepper assembly, and it was working
before, it's unlikely you affected the alignment - but if you did, ImageDisk
has a function the help align the drive to a known well aligned disk (best to
use a official "alignment disk", but one formatter to a new or known good
drive is usually "good enough").
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
