First post, by severinmazarin
First some background.
I managed to design and wire up a prototype memory expansion card for my IBM 5170. Despite the mess of wires, it actually works just fine! Since making custom cards is completely new to me, I decided to start by making an 8-bit card. Would like to try designing a 16-bit card later.
So the current memory configuration is 512 kb on the motherboard, and 128 kb on the expansion card. If I understand things correctly, RAM speed should be half on the expansion card compared to the motherboard (16 vs 8 bit data bus). But I would still like to test this. Haven't yet found a way to do so.
Ideally I would like a utility where I can point to and test read and write speed for a certain range in memory, like 80000h - A0000h (512 - 640 kb), to be able to compare it to the lower segments. So far all utilities I've tried to use, requires a 386 or newer. Have no idea if they can even do what I want. I have also dabbled a bit in DEBUG, but have only gotten as far as dumping the contents of memory. Another idea was to create a ramdrive, but I am not sure if there is a way to choose where in memory it should be placed.
Any ideas? Thanks!
Reply 1 of 12, by bakemono
It will be less than half speed, because 8-bit memory cycles have additional wait states. (16-bit cycle is normally 3 clocks. 8-bit is 6 clocks, to make it closer to XT speed.) I think I have a speed test utility, I can look for it later.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 2 of 12, by rmay635703
bakemono wrote on 2025-09-09, 09:04:
Can’t an 8 bit memory card be wired to force 0 wait state like a 16 bypassing that or is the original AT always inserting them.
Next there is a utility that measures the speed of every kb of ram to test cache speeds (somewhere, everyone here screenshots it). I think it works on 286.
Reply 3 of 12, by Jo22
rmay635703 wrote on 2025-09-09, 19:53:
8-Bit memory boards in an AT bus slot can do that, I think.
There's an 0WS pin on the 8-Bit portion. Pin B8, I think.
On PC/XT systems, the pin had a different purpose (related to slot 8).
More information:
https://www.lo-tech.co.uk/wiki/IBM_Personal_C … em_Board_Slot_8
Reply 4 of 12, by rmay635703
Jo22 wrote on 2025-09-09, 20:48:
8-Bit memory boards in an AT bus slot can do that, I think. There's an 0WS pin on the 8-Bit portion. Pin B8, I think. […]
On PC/XT systems, the pin had a different purpose (related to slot 😎.
More information:
Since zero wait states on an ISA device is sort of a “when other stuff is ready “ “as fast as I can go boss” scenario it would be somewhat interesting to compare a 0ws 8bit to 16 bit ISA memory device to see if any other collisions make it worse.
If I remember correctly 16 bit reads and writes to an 8 bit peripheral have other horrifying bottlenecks
but with zero wait states 8 bit ISA theoretically Should be able to move nibbles and byte sized data faster than the onboard very slow 16 bit ram with its hard coded wait states.
Always felt funny that a true IBM 5170 could technically use properly designed 0ws 16bit ISA ram faster than its own onboard stuff in most circumstances.
Reply 5 of 12, by Jo22
rmay635703 wrote on 2025-09-09, 21:26:
Hi! That reminds me of the XT/286 model. If memory serves, didn’t it have 0WS memory?
This is so odd, it basically was the highest end model in an "antique" PC/XT chassis! 🤣
Reply 6 of 12, by Pickle
i think your thinking about speedsys (show graph) there also cachechk which shows the usec for every address
both are included in phls computer lab benchmark pack.
checkit has a memory tester but does nothing about speed.
Reply 7 of 12, by Jo22
Syschk has some benchmarks, but I don't know how detailed it is.
Reply 9 of 12, by severinmazarin
bakemono wrote on 2025-09-10, 20:14:
This utility should test each 64KB region.
Thank you, this works. The results are approximately:
~ 2950 (kB/s ?) for the motherboard memory
~ 1040 (kB/s ?) for the expansion card SRAM.
This is pretty much in line with what ChatGPT told me, at least theoretically. 1/3 speed for 8-bit expansion memory vs 16-bit motherboard memory.
Reply 10 of 12, by rmay635703
severinmazarin wrote on 2025-09-16, 13:38:
Thank you, this works. The results are approximately: […]
Were you able to set the 8 bit card to 0ws?
Reply 11 of 12, by rmay635703
rmay635703 wrote on 2025-09-16, 22:08:
Also 3mb/s memory bandwidth on a 286-8 seems low, I was trying to find a chart of memory bandwidth real world on various 286 systems but haven’t had much luck
Reply 12 of 12, by maxtherabbit
Speedsys requires 386, but cachechk should work
