First post, by Hirsch
I got hands on two Hercules Dynamite Pro ISA cards both equipped with 1MB. They work fine so far. Both cards are equipped with 16 sockets having chips in 8 of them (the rows of U13, U14, U15, U16 on the photo attached.) According to Wikipedia the Tseng ET4000/W32i on that card should also support 2MB:
https://en.wikipedia.org/wiki/Tseng_Labs_ET4000#ET4000/W32i
Furthermore, you'll see this card occasionally equipped with 2 MB on a known auction site. From this I draw the conclusion, that a memory upgrade must be possible. I tried to upgrade the cards without success trying:
- I ordered Siemens HYB514256B-60 chips from China to upgrade the cards. They have the same pinout and specs as the original Mosel-Vitelic V53C104HP45 chips on the card. The only difference is, that the Siemens chips have 60ns while the Mosel-Vitelic have 45ns. ChatGPT told me, that 60ns should be sufficient for the ET4000/W32i.
- Replacing the original chips with the Siemens chips (just replace, not upgrading) works fine. I see no artifacts on Windows 98 on different resolutions. This tells me that I didn't buy fake chips and that ChatGPT didn't lie.
- When putting the Siemens chips in the free sockets only 1 MB is recognized (on both cards).
- I pulled the Mosel-Vitelic chips from one card and put them on the other card. It still recognizes just 1MB (this is the photo attached).
- I tried out different jumper settings with J1 - J4, also no success.
Since the card does not display the VGA BIOS output using an Asus P/I-P55T2P4, I used Navrátil Software System Information to see how much memory was detected. I also started Windows 98 and tried to switch the resolution to 800x600@16M color which requires 2 MB. Windows changed the resolution, but it was 800x600@65k color instead.
Since the behaviour is the same on both cards I assume it isn't a corroded socket. Do you have any hints what needs to be done (other BIOS, opening/closing solder bridges, ...)?
