First post, by Feanor_twh
I got a Shuttle HOT-591p to replace my old SS7, which hadn't worked after several years in the closet. It came with a K6-2 300 configured at 66x4.5, which worked fine, until I installed my K6-III 400, and then everything went wrong. It wouldn't even boot, but when I went back to the K6-2, it wouldn't boot either, until I discovered, after much testing, that the problem was with the 100MHz FSB. Neither of them work at all with that FSB, and they do work at 66MHz. I tried 95MHz (86MHz real) and they work but with memory issues. I have yet to try 75MHz, but even if it works, it's a regrettable performance loss.
What am I missing? I thought it might be an outdated BIOS, but that seems unlikely. This motherboard has automatic voltage, but I tried manual adjustment, but nothing. Also tried RAM at AGP speed and FSB speed, and it's the same thing.
It's driving me crazy, but I can't just abandon this project because the other components are so great and fit together perfectly.
