Are you still using Windows 7?
First post, by OM606
I've come to realize that the OS i use the most nowadays is Windows 7 again. I've completely stopped gaming and lost my interest for hardware around 2013 and have been using Linux most of the time ever since.
My golden era of games and hardware is 2004-2009 when i was a teenager. I still had hardware from 2011-2014 laying around built some kind of "overkill" XP rig and ended up dual booting Windows 7 because i wanted to play the last games i really enjoyed 10-15 years ago such as Metro 2033, Bioshock Infinite, Far Cry 3 and Doom 2016.
I ended up installing my favorite games from the 2000s on the Win7 partition and realized that except for not being able to enable EAX through Alchemy in FEAR, the experience was just has good and didn't require more tweaking. All the tweaking i had to do under XP was hardware related (such as cfg files to fix texture and resolution issues in games likes Doom 3, Quake 4 or Prey) and is the same under both OS. I had some occasional crashes under XP that are not happening anymore since using the LAA (Large Adress Aware) patch under 7 x64. Assassin's Creed, i'm thinking about you.
I find myself using this PC a lot for pretty much anything that isn't online and i think 7 is still a relevant OS and maybe the pinnacle of what MS could do and certainly the last great Windows for offline gaming. I wonder how many of you are still using it and how do you feel about it being 16 years old. I guess it could be nostalgic for someone younger than me, similar to what XP is to me. In my case, i just think it is a solid OS and the one i'm the most familiar with.
On a side note, i'm not sure XP is that relevant for games from the Vista era. Most of my favorite games are from this weird era having EAX and DX10 at the same time. I guess this build became the Overkill x64 DX10 2007-2009 PC. It seems like my other build is doing a better job at a straight forward XP rig.
Win7 x64 - Xeon E3-1271 v3 - Z97X-UD3H - GTX 960 - SB0880
WinXP - Q6600 G0 - P5B Premium - 8800 GTS 640 - SB0880
Reply 1 of 67, by RandomStranger
Barely. I have a T630 thin client with Windows 7, but it doesn't see much action. For nostalgia I mostly use XP and Windows 98 and daily drive Linux which out of convenience also covers most of my gaming needs. The rest is shared between my XP rig and 7th generation gaming consoles if I crave for the authentic experience. Or for certain publishers to avoid their online services (Ubisoft, EA, Rockstar).
Reply 2 of 67, by Cyberdyne
All my interneting, bill paying and doomscrolling is made with an android phone. So my computers are mostly offline. I have one box and one laptop that have Windows 11. Everything else is mostly Windows 7/XP or old DOS. I would use Windows 7 to the end of times, if it were safe in the internet. There still is Firefox ESR. And few antivirus software. But ID card software does not work. And everything is unsafe.
Reply 3 of 67, by Barley
I have been dual booting Windows 11 and Windows XP, but I think I will change that to Windows 7 and Windows XP.
The issue I have with dual booting 11 and XP is that 11 is limited to a GTX 980 ti (let alone an Ivy Bridge cpu) so I can't really play any of the latest games. Also, just about the only sound card that spans that generation gap (without core isolation issues in W11) is the Audigy RX, which does not have EAX 5.0.
So I will put Windows 7 on there and use an X-Fi Titanium for EAX 5.0 goodness. Most of my games do just fine on Windows XP, but having W7-64 bit on there will allow me to use all the mods and widescreen fixes that are not compatible with Windows XP.
This will free me up to build a new-ish (not really) Windows 11 box with a 2070 Super I have laying around.
Reply 4 of 67, by Archer57
Not really. Guess this mostly depends on what period of time you remember/like the most. For me it was XP. Vista/7 always felt no more than a stepping stone i have to endure because there are no other options. A significant downgrade from XP. Pretty much as bad as 10/11.
Nowadays i mostly use XP for old stuff and either modded 11 or linux for modern stuff. I would have switched to linux entirely long time ago, but desktop linux is so comically bad it did not even reach XP level of functionality by this point. Notably no application level firewall is just... perplexing.
I also have completely offline (Or should i say violently offline? I've desoldered NIC IC from the motherboard 😁 ) 11 system for games which is mostly used by kids, but i also use it to play stuff which does not run on XP.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 5 of 67, by SuperDeadite
I dual boot 10/7. Mostly use 7 for a lot of Japanese games that require old directdraw features and MIDI stuff.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 6 of 67, by Shponglefan
I currently have no Windows 7 systems and as of last weekend, no longer have any Windows 10 systems either.
Though I have been thinking of converting my Ultimate XP build into a triple OS system with XP, Vista, and Win7.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 7 of 67, by kolderman
Its my main retro emulator system. I.e. dosbox, scummvm, etc. I also licensed my Roland SoundCanvas VA there, meaning I am tied to that particular OS install. Works perfectly on my core2duo build, and is dual booted with WinXP for XP era gaming too.
Reply 8 of 67, by chinny22
Your golden era is bit newer than mine which mostly finishes around 2004.
But somewhat like you I found I used my XP rig most, even for the Win9x era games rather then using my earlier systems. It's easier as most game's just work and the newer OS requires less tweaking.
So I think it's quite normal for someone to use their newest fondly remembered OS even over the more period correct choices.
Personally I think WinXP was the pinnacle (again probably a generation thing) Windows 7 was just ok and anything newer I have no attachment and only use to complete a task.
I do have a dual boot XP/Win7 PC in my gaming fleet and even though has an X-Fi card I only really use for Win 7 and the few games that wont work in XP.
I still prefer my dedicated XP rig for XP era games even though it makes no real difference to the game.
But I've also decided Win7 will be my last gaming PC and have managed to "find" a offline install of one of my 2 games on Steam, Missing out on any new content doesn't bother me.
Reply 9 of 67, by Ozzuneoj
SuperDeadite wrote on 2025-09-19, 00:12:
Interesting, can you explain what DirectDraw and MIDI stuff was available in 7 that isn't available in 10? I have never heard of this... but I wouldn't mind having a reason to revisit Windows 7. It's been a while. 😁
Reply 10 of 67, by Shagittarius
Enjoying windows 11 unless specifically using one of my retro machines.
Reply 11 of 67, by Robbbert
I've got a bunch of Windows 7 machines, used for different things and also some spares. So, two machines are on the internet all day, for the usual things one does on the internet.
Other offline machines host my music jukebox activities, and also my database server. However I don't use any for gaming.
They are all up to date (windows updates) as of last year.
So, I do intend to keep using them as main machines for a while yet.
Reply 12 of 67, by Ozzuneoj
Robbbert wrote on 2025-09-19, 04:15:
I've got a bunch of Windows 7 machines, used for different things and also some spares. So, two machines are on the internet all […]
Not trying to fear-monger here, but when you say they are up to date as of last year, what do you mean? Windows 7 hasn't gotten regular security updates in almost six years. Any updates it gets are simply anti-virus definitions, or in rare cases MS can roll out patches for extremely serious vulnerabilities, but I don't know if they have actually done this since the end of support.
In my opinion it's totally okay to use an old OS if you're comfortable doing so and anyone else using the PC knows that there is some additional risk compared to a newer OS, but I don't think I'd call it up to date in the same sense that a Windows 10 or 11 system can be up to date with the latest security patches. Like, if my wall clock died yesterday I can say that the time is up to date as of yesterday, but... well, you get the idea. 😀
Reply 13 of 67, by Joseph_Joestar
I like using Win7 for the few games from the late 2000s which still support EAX, but also use DirectX 10 for improved graphics. There aren't many of those, but some notable examples include BioShock, Assassin's Creed, Gears of War and Far Cry 2. For reference, you can more easily install Creative's older drivers on Win7, and that can be useful for avoiding some bugs with OpenAL.
That said, I use Win7 completely offline, as Steam dropped support for it a few years back. Any games that I play there have either been previously downloaded on Steam (which is now in offline mode) or they were installed using GOG's offline installers.
Also, Win7 seems to support DirectX 8 games slightly better than Win10/11. As an example, Thief: Deadly Shadows (an UE2 game) has non-functional V-Sync on Win10/11, while it works fine on Win7. I think a few other UE2 titles might be affected as well.
Reply 14 of 67, by SuperDeadite
Ozzuneoj wrote on 2025-09-19, 02:42:
I don't know technical details, but Win8 and after crippled legacy directdraw support. Lots of games were broken by this. These days, there are wrappers to get around it, but I find compatibility with Japanese stuff to be very poor.
Regarding MIDI, Win7 just requires far less effort to get things working. I appreciate all the work that people have done to fix MIDI issues on 10, but on 7, it just works.
Also, I have a very specialized Micomsoft capture card. On Win7 drivers it can capture raw 240p RGB. On Win10 drivers, that feature was removed....🤣.
Reply 15 of 67, by DaveDDS
I still have (at least):
10 Win7 desktops (-2dualW7/W10 +2W10only +3DOS)
4 Win7 laptops (-2dualW7/XP +2W8only +4W10only +3XPonly)
I mostly run my own stuff, and what third-party/commercial stull I
do use is pretty "old school" (before "always online" mentality)
Not really fond of the way things have been moved around in W10, nor
the "always update - even when no problems" mentality... You might guess
I don't like things changing for no reason.
Most of these are NOT connected to the internet (I maintain a
second router to enable them to be on a network without internet)
For internet, I use Email, this (and a couple other) forum, and google
searches from time to time... So far I can still do these under Win7 but
I know the incompatibility is coming ... my solution was to pick up a
couple "chromebooks" .. I don't use them for anything else, so I don't
care that they auto-update, and easy to access files on USB sticks for
upload/download ability etc.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 16 of 67, by Shagittarius
DaveDDS wrote on 2025-09-19, 11:20:
I still have (at least): […]
What is your setup like that you need a separate router to stop internet access, I'm currently studying for CCNA Certification and I would like to know the reason for this configuration, I have gaps in my knowledge.
Reply 17 of 67, by DaveDDS
Shagittarius wrote on 2025-09-19, 14:19:
What is your setup like that you need a separate router to stop internet access ...
Oh... I doubt I actually NEED it ... I'm sure I could assign IP addresses
and block the individual systems on my primary router... I just tend to take
the "easy" way when I can...
On my primary router I can block any traffic from the connection port to the
gateway... makes it easy - and if I'm trying something tricky, I can unplug
one cable to make sure they are disconnected from "the world".
I happen to have a "box" in my basement with probably nearly a dozen
old routers, was very easy to just use one of those, and as most of
my older systems are near each other, also avoided running long cables.
Plus some of my older laptops can't do WPA2 .. so the second router
provides easy wifi access without having to spend days trying to find
(quite probably non-existant) drivers for old hardware.
Reply 18 of 67, by gerry
OM606 wrote on 2025-09-18, 17:55:
similar, add gog, patches and dosbox and it becomes possible to play almost every pc game from early days through to more recent times - the limit being my hardware & graphics card. I'm covered for 80's through to around 2015ish. Win 7 has the advantage of working well on a range of hardware.
I used to play some games on an XP machine and some on a 98se machine - I still do a bit but not of necessity really.
Reply 19 of 67, by BaronSFel001
I have seen the footage as proof: it would be safer to put a Windows 9x PC on the open internet today than anything using the Windows NT kernel no matter how old it is.
System 20: PIII 600, LAPC-I, GUS PnP, S220, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
