Voodoo 2 repair advice
First post, by jamesfmackenzie
Hi all!
I bought an (allegedly!) working Voodoo 2 card, but having some challenges.
Full details are below. I am out of ideas and seeking Vogons expertise. Any fix help/recommendations/advice very much appreciated! 😎
The card
Visually the card looks very good. All components are present and correct, and no visible damage other than (possibly) some glue on some traces (see below).
The attachment IMG_3739.jpeg is no longer available
The attachment IMG_3741.jpeg is no longer available
The attachment IMG_3742.jpeg is no longer available
The behaviour
Although VGA passthrough works, the card is not detected or recognized at all. It appears completely dead.
In case it’s useful, the FBI, TMU and GENDAC chips do get warm to the touch.
Investigation so far
1. Visual inspection of the PCB - all seems good.
2. Try on several machines - I tried the card on 4 retro PCs including a period appropriate 440BX machine. The card is not detected on any.
3. MOJO diagnostic tool - the card is not detected.
The attachment IMG_3734.jpeg is no longer available
4. DOS-based PCI tool - the card is not detected.
The attachment IMG_3735.jpeg is no longer available
5. Check for shorts with multimeter - none found across any PCI pins.
Any recommendations on what to try/test next?
It seems that perhaps the FBI chip could be faulty, or maybe I should get a microscope and start examining/testing individual traces more thoroughly?
All help/expertise much appreciated! 😎
Reply 1 of 15, by sdz
Mojo should detect the card even if all ICs except the FBI and the linear regulator are removed.
Most likely FBI has loose pins, that look ok but aren't actually soldered anymore. Other possible reasons, dead FBI (unlikely) or broken PCB traces/VIAs. Might also want to check that the voltage supplied by the regulator is around 3.5V.
Poke the FBI pins *gently* and see if any are loose.
Reply 2 of 15, by zuldan
Have a look at Jaton Voodoo 2 - 12MB not working [REPAIRED] for some tips and hints as to what to look for. sdz is 100% right, probably some loose legs.
Reply 3 of 15, by H3nrik V!
Following, as I have one based on the same reference design, that behaves excactly the same way, except:
Mine does detect in Win98 and driver installs. I'm not sure if you have reported whether or not your card does that?
Reply 4 of 15, by jamesfmackenzie
H3nrik V! wrote on 2025-09-21, 18:09:
Mine doesn’t detect in Win98 either 😎
Reply 5 of 15, by jamesfmackenzie
sdz wrote on 2025-09-20, 18:01:
Thanks for the tip!
Checked the voltage regular. A very reliable 3.49V or 3.50V - so we’re looking good there.
I checked the FBI and there *is* one loose pin. It feels like I need to reflow the FBI chip? Any recommendations on the safest way to do that? (I don’t want to overheat and damage the FBI 😎)
Reply 6 of 15, by sdz
Don't reflow it, just solder that one specific pin.
Reply 8 of 15, by H3nrik V!
Just did a reflow with hot air on one of mine - actually ended up with more loose pins than it had before ... Sigh ... So yeah, follow the advice from sdz 😀
Reply 9 of 15, by jamesfmackenzie
H3nrik V! wrote on 2025-09-25, 13:45:
Reply 10 of 15, by butjer1010
Look also for such places (black circles on pictures), and scratch a little bit onto this traces (black lines) to see if there is continuity. This upper looks like a broken trace, but maybe it is ok. Try it....
Reply 11 of 15, by jamesfmackenzie
butjer1010 wrote on 2025-09-25, 16:36:
Got spot! I tested the top trace and it is broken.
What’s your preferred way to fix?
Reply 12 of 15, by Pickle
jamesfmackenzie wrote on 2025-09-25, 16:45:
usual way to fix is sand/scrape off the solder mask before and after the break (and inbetween).
tin the exposed trace. Small breaks the tinning might bridge the gap, if so skip to the new solder mask step.
if its to large or you want added support use a wire. clipped legs from resisters/capacitors are great for this. bend the wire (sometimes you can bend as you solder) to the shape of the trace and solder it to the top of the trace.
check for continuity and if good apply new solder mask (i just use nail polish)
Reply 13 of 15, by H3nrik V!
I usually find it difficult to find room for a resistor lead. I'm those cases I use a single strand from a wire - sometimes 2, tightly twisted and tinned before placing them
Reply 14 of 15, by butjer1010
As Pickle said, if the gap is small, just scrape the trace near broken part (i use engraver to scrap, but You need to do that very carefully, very short time, or engraver can "scrape" whole trace in less than a second), and add flux and solder tin. If the gap is bigger, just use some kind of thin wire, and after scraping the trace, solder wire to bridge the broken part.
But i believe the most important thing with all Voodoo cards, is resoldering the pins on all 3 chips. I did fix at least 4 or 5 with this (although, none of them wasn't dead, they had smaller problems like no full memory shown or artifacts,...)
And also look if there is more spots like this one 😉
Reply 15 of 15, by myne
I had similar.
Check all the FBs.
They are ferrite beads, and basically only resist high frequency noise.
If they are open circuit, short it with a solder blob and retest.
One dead fb =dead card.
I think mine was fb2
I built:
