First post, by ux-3
My plan is to build a single machine for almost everything (oh no!) from about 2002 to the point the games can run on win 11.
So the machine is to run Win XP pro 32 bit, Win7 pro x64 and Win 11.
(I somehow assume that there is no important game that is win10 only? If so and it matters to me, Win 10 will be added to the list.)
I decided to go for the obvious and build from my inventory:
CPU i5-3550 nonK (up to 4 GHz capable on Z chipset)
ASRock Z77 Pro4
4x4GB Ram
GF-970 (xp patched driver)
quiet LiteOn DVD+RW
2.5 inch dual swap bay
I created the installs on different SSDs, all installs are capable of ahci. For WinXP, I used an Intel Postville 180GB along with Intels manual trim software.
For Win7, I created an install with SP1 and one with SP1 updated to the EOL. (to experiment with safedisk games and other problems)
Win 11 I installed out of curiosity, to have a testbed to see if old stuff might still work on the current OS without messing up my main computer in the process.
Win 10 I skipped, assuming that I will not need it.
I still have a Soundblaster X-Fi Platinum that I may add, but I have not bothered to include it yet. Would it have support under 11? I currently can go HDMI through my AV-Receiver to the display. I am not sure if I want to change that for the X-Fi.
Games that require early Nvidia drivers/shaders are out, as I will have to use late drivers for the GF970. Those games will have to run on Win98SE instead and live with a GF-4. Quite a gap, I know. Would I actually gain compatibility on GF460, or would I only lose speed?
WinXp should allow games with disk protection, so should the early Win7, before they patched Safedisk out.
At this point, I am a bit uncertain if I will actually need Win7 much?
I know Shponglefan did something similar 3 years ago, but I didn't want to abuse his thread ( Ultimate Windows XP Build (Intel i7-3770k / GTX 980Ti / 24" Asus ProArt display / X-Fi Titanium) ). He added a bit more muscle to the cpu and gpu by using i7-3770 and GF-980ti, but I don't own those components and I really don't see the need.
If you have any suggestions, cautions or installation advice, please add it here.
Thank you.
Edit:
This build has two "adjacent" machines:
- A win 11 i5-9600KF with a 4070 super for everything "modern".
- A win98SE on Asrock Conroe with GF 4200ti and Voodoo² SLI for windows games that won't run on late XP.
Basically, games will end up on the fastest machine they work on.
Retro PC warning: The things you own end up owning you.
Reply 1 of 33, by BaronSFel001
This is why there is no such thing as an all-encompassing retro PC. Windows XP is obviously its own thing; when it comes to anything afterwards you pretty much need only one edition from Vista to 8.1 unless DirectX 12 is demanded, and while Windows 7 is everyone's favorite that's the same reason you should avoid letting this system touch the internet. What it will come down to is exactly which games you are interested in playing (and at what quality); most anything 2020s is going to be too much for your specs.
I had a similar undertaking last decade, converting my Windows 8 business-class PC into a super system for XP & Vista gaming: just added the GeForce plus X-fi (along with upgrading the power supply to handle them) and that was that. The only real complication was with Steam DRM games (which is why I preferred to avoid those back when I could) when Valve discontinued support for those OSs, but some workarounds work better than others. As of 11 I am done with Windows, figuring my Xbox One X can manage anything my Steam Deck can't [and whatever requires something more powerful I am probably not interested in].
System 20: PIII 600, LAPC-I, GUS PnP, S220, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 2 of 33, by ux-3
BaronSFel001 wrote on 2025-09-09, 18:50:
Sure. But it is only supposed to run what Win 11 can't run on my current non-retro rig. I wonder how far in time one has to go back to find a game that won't work OK on win 11 but needs an older OS?
That was a setback. I tried to aquire most titles through GoG though, if I had a choice. What workarounds for steam do exist?
Reply 3 of 33, by fosterwj03
The i5-3550 and GTX 970 are solid choices for Windows XP and Windows 7 32-bit. They might begin to bottleneck on Windows 7 64-bit and Windows 11 with modern AAA games. You can go with much more modern CPUs and the GTX 980 Ti, but you'll run into bottlenecks eventually. You also get into Windows XP "Unsupported" territory beyond Haswell platforms.
Like I said, solid choices and it will certainly handle late 20-teens AAA games with ease.
Reply 4 of 33, by chinny22
When Windows 7 was about to be dropped by Steam that was when I built my Win7 PC, Installed my only 2 games I own on Steam (C&C Remaster, Euro Tuck Sim) and took it offline.
Both games still work in Steam offline mode, although can no longer update ETS.
So I can see the benefit of doing something similar in your case with Win11 (but don't think they differ much in resource usage)
I agree, it may be you don't actually need Windows 7. I'd install the more demanding games, see how then run in 11, and only worry about Windows 7 if games are struggling.
I'd install the X-FI, at least for XP this will give you EAX. I think later versions of Windows 11 no longer work with the official X-Fi drivers but are ok with the DanielK
I'd say its worth a test build and see how well it works as it comes down to what games you want to play.
I own very little demanding XP titles let alone Win 7 so find a GeForce GTX 780 is more then enough for my needs.
Reply 5 of 33, by Archer57
Even late XP games often run fine on modern hardware and OS. Vista/7 - even more so. Yes, occasional issues exist, but critical ones are not common.
What's more problematic is early-mid XP stuff. And here too new GPU may be... problematic. Even GTX660 i have ends up creating issues for quite a few games. Some do not run at all, some have issues, sometimes unacceptable ones. GTX970 will be even worse.
Ultimately depends on specific games you want to play, many will run just fine, but it is not going to be "a single machine for almost everything".
You may want an older GPU. Then the system will be able to run more older games, sacrificing ability to run newer stuff which'll probably run on modern hardware just fine...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 6 of 33, by ux-3
Thank you for your views.
The oldest card I have for this build would be a GTX-460. I doubt that I would solve many problems by going back those 4 years from 970 to 460.
Regarding steam: I kind of planned this computer to be off the internet anyway. I will instruct my router not let it go online.
Funny you mention this. One motivation of this build was to get "Silent Hunter III" back running. The disks have copy protection and work out of the box on win XP. I also had the "gamersgate" version of the game which required an activation and was then working diskless. But the activation servers are gone by now. And I had the steam version, which I can only install on win 11. I tried many "fixes" from the net but no dice. And then I just set win 11 to 1024x768 and BANG! Works. Many games do work on win11 where you would not have expected it, given the fuzz they made on older versions.
Reply 7 of 33, by Joseph_Joestar
Archer57 wrote on 2025-09-10, 03:08:
I think this largely depends on which games you're playing. For me, the GTX 970 and 980Ti with 355.98 drivers (modded) played most of my favorite WinXP titles from 2001 onward without any major issues. Here are some games that ran well on those cards under WinXP, along with my notes on needed fixes/adjustments, if any:
2001
  • Baldur's Gate 2: Throne of Bhaal
  • Deus Ex GOTY
  • Gothic (inventory icons are slightly distorted)
  • Icewind Dale: Heart of Winter
  • Max Payne (anti aliasing should be turned off)
2002
  • Morrowind
  • Need for Speed: Hot Pursuit 2
  • Neverwinter Nights
  • Star Wars: Jedi Knight 2
  • WarCraft 3
2003
  • Deus Ex: Invisible War
  • Gothic 2
  • Max Payne 2
  • Prince of Persia: The Sands of Time (needs ForceVSFog=1 InvertFogRange=0)
  • Splinter Cell (needs ForceShadowMode=0)
  • Star Wars: KOTOR (needs Disable Vertex Buffer Objects=1)
  • Tomb Raider: The Angel of Darkness
  • Unreal 2
2004
  • Doom 3 (needs seta com_videoRam "1024")
  • FarCry
  • Half-Life 2
  • Prince of Persia: Warrior Within
  • Splinter Cell: Pandora Tomorrow (needs fan made fix for shadows/lights)
  • Thief: Deadly Shadows
  • Unreal Tournament 2004
  • Vampire: The Masquerade Bloodlines (needs unofficial patch by Wesp5)
2005
  • Battlefield 2
  • F.E.A.R.
  • Prince of Persia: The Two Thrones
  • Quake 4 (needs seta com_videoRam "1024")
  • Splinter Cell: Chaos Theory
2006
  • Battlefield 2142
  • Gothic 3
  • Neverwinter Nights 2
  • Oblivion
  • Prey (needs seta com_videoRam "2048")
  • Tomb Raider: Legend
2007
  • BioShock
  • Call of Duty 4: Modern Warfare
  • Colin McRae Dirt
  • Crysis
  • Unreal Tournament 3
2008
  • Assassin's Creed
  • Fallout 3
  • Prince of Persia
  • The Witcher
2009
  • Mirror's Edge
  • Risen
That said, these are mostly mainstream games with good support from both the developers and the fan community. It's possible that some niche titles from that time period might have more prominent issues on those GPUs.
Reply 8 of 33, by BaronSFel001
ux-3 wrote on 2025-09-09, 19:39:
Not something I want to risk breaking forum rules to elaborate on too much, but PCGamingWiki can be your friend (depending on the game) while anything involving DRM override is something you will have to do your own homework on.
Reply 9 of 33, by RetroPCCupboard
Personally I would add that X-Fi to the system. Games that support EAX sound much less flat. Though I guess not everyone likes the EAX sound.
Reply 10 of 33, by ux-3
I should call the machine "Trinity", because it ends up doing Trinity testing. So far, I managed to run all games I tried on win11 in the end. I started out with Age of Mythology Gold, then tried the Warlords series, then tried Battle for Middle Earth II. I must say, I am surprised how well these games seem to run - at least superficially. Haven't had time to check the details, so I may still discover some problems. I'll just downgrade the OS then and see if I can recreate the issue.
I came across some irritating Nvidia driver detail which I seem to remember wrong. I remember that when using a digital connection to the display, the driver would allow me to set the aspect scaling to the card. But I didn't find it in the latest XP driver (which I need for the 970). Was that added only in Win7? (I can set the screen to 4:3 too)
Reply 11 of 33, by fosterwj03
That feature was dropped in the Nvidia Control Panel, but GPU scaling is still present in the driver. You have to run a command from the prompt to enable it.
Open CMD.EXE as an administrator.
Type the following into the command prompt:
%windir%\system32\rundll32.exe NvCpl.dll,dtcfg setscaling 1 DA 5
The screen will flash. When the prompt curser returns, reboot the computer. GPU scaling should work after reboot.
Reply 12 of 33, by Joseph_Joestar
ux-3 wrote on 2025-09-22, 16:44:
You don't need the latest WinXP driver version for the GTX 970. It will work fine with the modded 355.98 driver, which is what's recommended in this thread if you want functional scaling.
As @fosterwj03 said, you may need to fiddle with custom commands to turn on scaling, but I could never get that to work reliably on my setup. Ultimately, I ended up getting an Asus ProArt monitor which has built-in 4:3 scaling even over a DisplayPort or HDMI connection.
Reply 13 of 33, by ux-3
Joseph_Joestar wrote on 2025-09-22, 17:41:
I skipped through that thread, but it seemed mainly concerned with refresh rates. I am not so worried about those, I want the scaling. So if I want to run 355.98 with a GF970, what do I have to do? same modding as with the latest driver?
Reply 14 of 33, by Joseph_Joestar
ux-3 wrote on 2025-09-22, 20:43:
Yeah, you mod the inf file to add the relevant entries for your GPU.
This page has all the necessary instructions.
Reply 15 of 33, by Barley
fosterwj03 wrote on 2025-09-22, 17:31:
That feature was dropped in the Nvidia Control Panel, but GPU scaling is still present in the driver. You have to run a command […]
I can't believe I've never heard of this until now.
Before reading this and trying this out for myself, I believed that the only way I could use a Nvidia card on a 1920x1200 monitor in Windows XP was with an ASUS ProArt monitor.
Now I am free to use any 1920x1200 monitor I want, which opens up plenty of possibilities on my end.
Many thanks!
Reply 16 of 33, by ux-3
Thanks for the suggestion.
Edit: Just found a way to access the hidden admin account. But by now I am back to 355.98, which I suspect will work just as well for older games as 36x will. I am not after new stuff.
Reply 17 of 33, by ux-3
Joseph_Joestar wrote on 2025-09-22, 21:37:
Lazy as I am, I took the nv4_dispi.inf from the mod I did for the late drivers and stuck it in the 355.98 files. 355.98 installed alright and now I have the options I looked for.
Thanks for the information.
Edit: And it really works like a charm. WinXP runs in 16:10 but the games automatically get displayed in their correct aspect ratio. That is how I remembered my late win XP days.
Reply 18 of 33, by Barley
Can you clarify what you did and what your results were?
From what I understand, you are using a GTX 970 card with a "digital connection to the display." Is that DVI? HDMI? DP?
Are you saying that with 355.98, you have working scaling options in the Nvidia Control Panel?
Reply 19 of 33, by ux-3
Barley wrote on 2025-09-23, 12:27:
I can try. 😉
I am using a GTX 970, which is not officially supported under WinXP. I modded the 36x driver according to the link provided above. I now need to mod the 355.98, but I just cut and pasted the modded file from the 36x driver instead. I used a DVI cable to an old DELL U2412M. But I just checked, I also have a working scaling option with display port (black bars left and right) to the old DELL. The 970 can also output just the original pixels with the "no scaling" option. The card then uses say sharp 800x600 pixels, with black borders on all sides on the DELL. As far as the DELL goes, scaling works in DVI and DP.
As the DELL screen has no HDMI, I just linked up the card to my 4k philips with HDMI.
Results on 4k: No scaling option with HDMI nor DP. However, I could not run WindowsXP in native 4k anyway. When I picked the resolution, the screen went black and never came back.
Just in case you wonder, if I switch the SSD and run the same hardware with win11, I do have all the options in 4k in HDMI and DP. And they seem to work at the native 4k resolution just fine. Atm, I can't check win7, I'd have to restore an image first.
