First post, by Linoleum
- Member
I am planning on repairing a Shuttle 557 v1.32 Socket 7 motherboard that I killed when assuming a PS/2 mouse header with 5 pins had the same wiring as a header with 6 pins. So I probably injected 5V somewhere I should not have...
The motherboard posts, displays image and does ram count. BUT it beeps like crazy within seconds of turning on, like when pressing all the keys at the same time; not like an error beep. Of course I get a keyboard error message...
I tested everything around the keyboard and PS/2 header for continuity (including the F1 fuse), and no problems there! So right now, I am planning on replacing the keyboard/mouse controller HT6542B chip... Is there anything else I should be looking out for? Is there even a chance I can fix it by just replacing the keyboard controller?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
