First post, by carlitosbala
I'm trying to get an ABIT KT7 board working. It currently turns on normally, i.e. it starts the fans when activating the power switch and it stops after holding the switch for a few seconds, but seems to not have any bios activity. Two different POST cards show just "--".
Having replaced bulged caps, checked voltages (all seem correct), and tested with multiple CPUs and RAM sticks, it's turn to flash the BIOS. And that is where I'm having issues 😀
This board has an Award bios which is flashed via AWDFLASH. I downloaded several versions of the bios, they all are a self-extracting EXE which extracts awdflash.exe, a bin file, and a couple of batch files which just invoke awdflash.exe. The bios which can be donwloaded from The Retro Web is just the BIN file, but that doesn't help. Maybe I just let myself go down the rabbit hole and missed a simple solution, but if not, I think I am at a dead end.
The BIN files are 256k, but I don't they are valid for flashing using an usb programmer. If I run hexdump on them, I get
$ hexdump -C kt7_zt.bin | head -2
00000000 25 fd 2d 6c 68 35 2d 1f 48 01 00 00 00 02 00 00 |%.-lh5-.H.......|
00000010 00 00 50 20 01 0c 4b 54 37 5f 5a 54 2e 42 49 4e |..P ..KT7_ZT.BIN|
So it seems to me they are compressed, but when I try to extract the compressed file it results in a 128k file. Which has some indication of being an actual bios file (having an "Award Decompression Bios" string and a few others that look like what one would see in BIOS menus), but is only 128k, and moreover it doesn't seem to be the only file in the BIN:
hexdump -C KT7_A9.BIN | grep -A2 -- -lh5-
00000000 25 3b 2d 6c 68 35 2d b1 3a 01 00 00 00 02 00 00 |%;-lh5-.:.......|
00000010 00 00 50 20 01 0c 4b 54 37 5f 41 39 2e 42 49 4e |..P ..KT7_A9.BIN|
00000020 00 20 06 71 20 00 00 2d e0 8f 80 fd d5 a4 ad ee |. .q ..-........|
0001b8c0 2d 6c 68 35 2d 9a 0e 00 00 d9 25 00 00 00 00 03 |-lh5-.....%.....|
0001b8d0 40 20 01 0b 41 43 50 49 54 42 4c 2e 42 49 4e fa |@ ..ACPITBL.BIN.|
0001b8e0 d2 20 00 00 0b be 7c 9a ee b1 b6 db ff 7b dc 38 |. ....|......{.8|
0001c780 a9 2d 6c 68 35 2d 03 02 00 00 42 06 00 00 00 00 |.-lh5-....B.....|
0001c790 02 40 20 01 0c 41 57 41 52 44 45 50 41 2e 42 49 |.@ ..AWARDEPA.BI|
0001c7a0 4e 88 96 20 00 00 01 b0 63 77 b1 b6 b9 5d c7 65 |N.. ....cw...].e|
0001e890 fc ca 9b 95 06 5a 40 00 25 44 2d 6c 68 35 2d 23 |.....Z@.%D-lh5-#|
0001e8a0 12 00 00 40 25 00 00 00 00 29 40 20 01 0c 5f 45 |...@%....)@ .._E|
0001e8b0 4e 5f 43 4f 44 45 2e 42 49 4e 42 dc 20 00 00 0d |N_CODE.BINB. ...|
0001fae0 e6 b8 00 23 5c 2d 6c 68 35 2d 9e 6f 00 00 00 e0 |...#\-lh5-.o....|
0001faf0 00 00 00 00 86 40 20 01 0a 56 31 31 31 30 34 2e |.....@ ..V11104.|
0001fb00 42 49 4e 22 85 20 00 00 29 a0 8e ef 5e 1d 9b 49 |BIN". ..)...^..I|
So, after seeing this I am thinking AWDFLASH.EXE doesn't just copy the original BIN, but instead takes those files and does who knows what with each. 7zip and similar programs do not seem to know about the additional files, so I'd have to extract them using a custom script, but even if I can get them, how would I know which order is awdflash putting them in the eeprom (or even if it uses all of them)?
With the board not working, I can't use awdflash, so the question is: Is there any way to have awdflash create the correct file to use in an usb programmer? Or is there any actual, usable BIN for this board anywhere? Did I just confuse myself and I'm missing something obvious?
Thanks in advance!
Reply 1 of 3, by Horun
Yes the 256k .bin files should work with an eprom programmer. The bios is a newer Award modular type which typically contain 2-5 compressed modules...
the Bootblock decompresses them on bootup and loads them into memory. the 128k is the main module, the AWDEPA.bin is a compressed logo, the other compressed modules are specific to the chipset....
Reply 2 of 3, by carlitosbala
Hi, thanks for confirming I was indeed going down the rabbit hole 😀
I thought I had found why the board didn't work. I will keep looking, but I now suspect the chipset itself, it is getting hot with the board on and no cpu...
Reply 3 of 3, by carlitosbala
just in case it is useful to anyone: it was the RAM. And of course, my lack of experience with this type of board. I checked a few different sticks and it ended up booting OK. I guess the first two or three I checked before either did not work, or were somehow incompatible.
Weirdly enough, however, my board now boots correctly with its "original" (e.g. currently programmed on the ROM) BIOS, but not with the ones I can download from the web. The original BIOS is a "normal" one, I can read the copyright notice once I dump it, not these "modular" files. In any case, next time I get to work on this board I'll check the bios version and run a few more tests.
Thanks for your help, @Horun
