First post, by d00mo
I can't get the audio driver to work properly in Freddy Pharkas... The music works fine, but the sounds only work initially - some initial sound can be heard in the very beginnning, then silence.
I have the CD edition and I believe the sounds are read from the CD. The sound card is Sound Blaster 16 (CT 2290).
HOWEVER, if I change the sound driver in the installation program from Sound Blaster to Thunderbird everything works fine! Very confusing...
I have tried GOSIERRA as well, didn't help...
Also, I tried it with another sound card, ESS AudioDrive.. works fine there as well (with the Sound Blaster driver).
Any ideas?
