First post, by MRVFONE
Hello all,
I have some old dos scsi drives / removables i want to speed test. But having issues finding a program that will bench mark other drives than the stock HDDs in my retro PC's in real DOS.
I have tried Phils Computer lab benchmark pack. But it will only do main hdd's not removables or scsi etc.
I have tried "read speed" Same as above.
What do other people use??
Thanks, Tim.
Reply 1 of 6, by Grzyb
Just create a large file, and then:
ptime copy /b testfile nul
"ptime" is any of the DOS ports of the Unix "time" command - see eg. the attached thing.
Works always, even with network drives, where there's no access to the sector level.
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 6, by AncapDude
If I remember correctly Dr. Hardware Sysinfo has a benchmark option with chooseable drive. Give it a try. It's Shareware and still buyable today if you like it.
Reply 3 of 6, by Disruptor
(troll) Coretest (/troll)
Reply 4 of 6, by Riikcakirds
In around 1994 with DOS 6.22 I used a batch file, very primitive using a 100MB folder.
echo %time%
xcopy /s folder nul
echo %time%
Then divide the 100MB by the time difference in seconds for MB/s.
I don't think dos batch files could do math operations back then, like subtracting to find the start - finish %time% difference.
Reply 6 of 6, by Grzyb
Riikcakirds wrote on 2025-10-11, 23:45:
echo %time%
Doesn't work in DOS 6.
The following does work:
echo.|time
