First post, by Htylol
@Dege Good afternoon, I'm really sorry that I'm straying from the topic, I couldn't find another way to contact you. I am a developer of the portproton application for Linux, recently added an application to flatpak and thought about how to make the application more versatile and user-friendly. One of the ideas is to add your functionality to run old computer games, and we would like to ask your permission, can I use your application for our project? Use the libraries, repackage them and upload them to github along with our project. Once again, I apologize for writing off-topic, the site of our project https://flathub.org/ru/apps/ru.linux_gaming.PortProton and https://github.com/Castro-Fidel/PortWINE
Reply 1 of 14, by legluondunet
@Htylol could you tell me if you can use dgVoodoo2 version => to 2.80+ on Linux/Wine?
From my side the last working version on Linux/Wine is 2.79.3
Reply 2 of 14, by Htylol
@legluondunet v2.81.3 still works (at least in portproton), but the above versions of dgvoodoo2 (v2.81.3+) no longer work (at least the glide api no longer worked). I also wanted to know about this... What game exactly did it not work in? Maybe it depends on the game. Worked for me on unreal (1998) 2.81.3
Reply 3 of 14, by legluondunet
Htylol wrote on 2024-04-23, 02:59:
It's not related to one game, I belong to Lutris team https://lutris.net/ and I write Lutris scripts installer for old Windows Games (Star Wars Episode 1, Moto Racer etc...), you can consult my scripts on my Github page here:
https://github.com/legluondunet/MyLittleLutrisScripts
I use dgVoodoo2 in numerous scripts installer and since 2.80+ version, dgVoodoo simply crash. For the moment It's not very an important issue because 2.79.3 still works very well.
I can reproduce this crash on different computer with different CPU/GPU.
I will try to debug my dgVoodoo crash with debug exe and submit it to Dege.
my config:
Manjaro 23.1.3 Vulcan
Kernel: x86_64 Linux 6.6.19-1-MANJARO
Proc: AMD Ryzen 9 5900HX
GPU: AMD Radeon RX 6600M
Drivers: Mesa 24.0.2
Resolution: 1920x1080
32 Go RAM
DE: Xfce4
Reply 4 of 14, by legluondunet
I joined you wine log using dgVoodoo 2.82.5 debug, hoping Dege will find something interesting.
All the games I tested with dgVoodoo2 2.80+ simply did not launch, crash directly (Moto Racer, Star Wars Episode 1, Tomb Raider III...).
I only tested directx games with x86 Ddraw.dll and d3dimm.dll, default options in dgvoodoo.conf.
Reply 5 of 14, by Dege
Htylol wrote on 2024-04-22, 07:41:
Hi!
I respect your project, but sorry, I don't want that. 😐
dgVoodoo has no business on non-Windows platforms anyway.
Reply 6 of 14, by legluondunet
@Dege: It's a very disappointing answer, but it's your project, your choice to not support other platform that Windows.
All the same, a big thank you for the work carried out which contributes to the conservation of old video games.
@Htylol: Happily dgVoodoo isn 't the only graphic wrapper out there. I advice you to try dxwrapper, DxWnd and cnc-draw, all this projects are open source and devs are open to Linux/Wine users.
Reply 7 of 14, by Bladeforce
Does the latest dgvoodoos not work because vkd3d isnt installed first? (D3D12)
Reply 8 of 14, by the-burrito-triangle
Last version of dgVoodoo2 that has worked for me was 2.80.2 (listed as "v2.8.2", released May 10, 2023 on github). Anything newer and all the games I use it with crash: old DDraw and Glide titles in Wine or Wine+DOSBox-X with Glide pass-through. This is with DXVK 2.51, VKD3D-Proton 2.13 and Wine 9.22 and somewhat recent MESA 23.6 on Fedora 39.
I suspect fixes are needed in DXVK/VKD3D-Proton/Wine for unimplemented features of D3D11 / D3D12 / modern Windows API used by dgVoodoo2 after Dege's refactoring.
As far as old DDraw titles are concerned, DXGL and dxwrapper have poor compatibility with most games I've tested them with. CNC-DDraw works most of the time but crashes in any DDraw title that uses "real" 3D graphics, e.g. Might and Magic 7 and 8. dgVoodoo2 works great for these type of games. For Glide titles, nGlide 2.10 can be hit or miss. Sometimes it works better than dgVoodoo2 and other times it is worse. nGlide's Vulkan 1.0 wrapper is worse performing than the D3D9 wrapper by a looooong stretch. Which is sad, since Vulkan is a native Linux graphics API. Even sadder, Intel Xe iGPUs take a giant dump in their pants with Vulkan but perform admirably well with OpenGL--even at 4K resolutions.
One of the big benefits of dgVoodoo2 is that Dege compiles 64bit Glide wrappers that can be used with 64bit DOSBox-X for Glide pass-through in a DOS or Win9x VM. I managed to get Unreal Tournament 1999 to play 60fps through DOSBox-X + Wine at 1600x1200 resolution while testing/benchmarking. But nGlide worked decently too (with 32bit DBX) and actually performed better on my iGPU when using D3D9 output with Wine-Nine/Gallium Nine. (My iGPU can play UT99 at 60fps in 4k with the latest XOpenGL engine from patch 469d and native Linux binary).
Reply 9 of 14, by legluondunet
Recent dgVoodoo2 versions are not usable with Wine, games simply crash at launch.
A bug was reported to Wine Team here:
https://bugs.winehq.org/show_bug.cgi?id=58731
Latest dgVoodoo2 version that fully works with Wine is 2.79.3
Reply 10 of 14, by UCyborg
I suspect there are number of games that only started to run well on Linux with combination of DXVK and dgVoodoo2. 7 years ago, I made some comparison screenshots with FPS counter of 1999 Drakan: Order of the Flame running on Linux. Besides some odd bugs taken care of in unofficial patch, it wasn't too problematic in general in graphics department.
https://imgur.com/a/drakan-linux-performance-BiPjt62
Slightly off-topic, but interesting to note regardless since this forum attracts lots of folks playing with ancient hardware, while helpful for newer GPUs, there's no good retro compatibility of these types of games on Linux, because you need Vulkan compatible GPU while on Windows you can still run these games OK with older pre-Vulkan GPUs.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 11 of 14, by Nostalgia_Realm
legluondunet wrote on 2024-04-22, 22:55:
I've created a fixed version of the latest release that works on Wine. Any testing would be appreciated!
Some of you in this community may have been aware that any dgVoodoo versions newer than 2.8 failed to run on Linux using Wine/Proton. I am pleased to share a fixed version of the latest DgVooodoo release (2.87.5 at the time of writing) with you all, however this will absolutely need some more testing. The patch should have resolved a seemingly deliberate detection of Wine (searches for 'wine_get') and the subsequent path the program will follow after a detection had been successfully affirmed.
This fix was vibe-coded using GPT-6 Astra, there's more details in the Wine-fix folder inside of the attached 7z file (use PeaZip or 7zip to unpack), and a README.md that clarifies what exactly was changed to make the fix work.
Note: This version is NOT from Dege, do not ask Dege about support for this. Ask me instead, I'll be happy to help!
[EDIT] attached files removed
Reply 12 of 14, by Dege
Sorry but you can't distribute modified versions of dgvoodoo files. Do it on private channels if you want.
Reply 13 of 14, by legluondunet
Nice work @Nostalgia_Realm, this anti-wine code is a disgrace.
