Reply 1640 of 1908, by NeoG_
Niemi_81 wrote on 2025-10-08, 17:16:On DOS side it reads CD images just fine, but i can't get any CD Audio. Settlers 2 informs that there are no CD tracks, Homm2 just hangs and gives a black screen..
Can you try Mechwarrior 2 in DOS? It's known to work well and we can figure out if it's an issue with the game or with the setup
wargrip wrote on 2025-10-08, 22:27:I have a question about running it side by side with a Awe64.
My Awe64 is set to irq 5, dma 5/1, MPU port 300 and I want to use my picogus for midi and then sometimes usb and sometimes gus. I was hoping I could switch between gus and usb in software without messing with jumpers but I'm not sure what irq to use - my understanding is that usb needs irq 3 to be set and gus needs irq 7 - am I wrong? is there an irq setting that could work for both? it is a serial mouse I am wanting to use in usb mode, fyi
Thank you!
Multiple modes of the PicoGUS can occupy the same IRQ as long as the software you are using allows you to select that IRQ. Since only one virtual device on the PicoGUS is ever using that IRQ at a time there are no conflicts. AFAIK using a GUS on IRQ3 is fine (7 is an option- not mandatory). As mentioned just make sure the environment variables and software are set up to look for a GUS on IRQ3.
Also USB mode only requires IRQ3/4 if you are using COM port emulation for a virtual mouse. If that feature isn't enabled you don't need a specific IRQ for USB mode and can use whatever you want for the GUS side.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
