First post, by Barley
I've acquired a plethora of old GPUs through various means. Before I get rid of the excess, I wanted to check if there were any uses for the cards that I am not considering.
For my W7/XP rigs, I am using GTX 980 Ti, GTX 970, R9 280X, R9 270 and GTX 750 Ti on Z97, X79, Z77, X58, and X38 platforms.
For W98, I will be using an X800 SE PCIe on P35 platform.
The cards I don't think I have a use for are: R7 260X, HD7770, HD4870, GTS250, HD4850, 8400GS. I know these cards won't work in W98. I have many better cards for XP, and they are underpowered for any more recent OS.
Am I missing any uses? Specifically, do any of these cards do anything in XP that the newer cards can't?
Reply 1 of 3, by Joseph_Joestar
Barley wrote on Yesterday, 20:36:
Some of those AMD cards likely support AMD True Audio. Very few games actually use that, but I figured it might be worth a mention.
On the Nvidia side, you may possibly want to keep one of the lower powered cards for 32-bit PhysX, since it's not supported on the RTX 50 series, and likely their future cards as well. I mean as a secondary GPU, only tasked with PhysX, but I'm not sure how feasible that would be.
Reply 2 of 3, by sunkindly
If you're interested in emulation at some point, the Radeon HDs are useful for being powerful enough while still having analog output.
SUN85-87: NEC PC-8801mkIIMR
SUN88-92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280
SUN94-96: BEK-P407 | Cyrix 5x86 120MHz | Tseng Labs ET6000
SUN98-01: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000
Reply 3 of 3, by chinny22
I don't have any advice about any advice about specific cards, just that having 1 or 2 test cards is always a good idea.
The exact cards don't really matter though, so could be whatever is worthless on the second hand market or some of the recommended above.
