Maj.Jackyl's Computer Lab
Reply 200 of 203, by Major Jackyl
So, I've set this LuckStar up three times now and have full function every time. No clue what was going on.
The attachment A845S_P41700.JPG is no longer available
The POST card effects nothing. This last time, I installed the wrong video card, but still functioned perfectly (just way faster). I even added a network card and transferred about 16GB of games. Definitely going to call this GOOD and add it to the collection.
The attachment 20251021_165423.jpg is no longer available
Over the weekend I cleaned and benched a Shuttle FB61 with Pentium 4 SL6WK (3.0/800/512), 2x1GB DDR400, and a very similar Radeon 9600.
The attachment Shuttle_Fb61_P43k_R9600.JPG is no longer available
I had to use my normal bench PSU (300W Enermax), since the 200W PSU in the Shuttle had plague™ and was broken, most likely from not being powerful enough. It's going to get a nice 350W retrofitted (needs ATX and P4 connectors).
ANYWAY, to the point: it was a similar setup to what I was messing with earlier and now that I got the 9600 in the board, I can compare the "same" video card in two similar systems with wildly different CPU clocks and memory, especially since the LuckyStar has 133Mhz SDRAM. The results are expected, but now quantified.
The attachment A845S_P41700_R9600.JPG is no longer available
I had my brothers' Shuttle race my Shuttle, for funsies; mine got blown out of the water. Of course, it DID finish first, but not a fair race, as the GF4 was missing many feature tests. My Shuttle runs Athlon 64X2-3800+(2.0Ghz) 2x512MB DDR400, and GeForce 4 MX4000. I didn't get pictures of his while it was here, but it was way slicker-looking than mine, with a 2mm aluminum plate on the front.
The attachment FN95_MX4000.JPG is no longer available
Going to do a recap now. Not sure what, but it's going to get done, 🤣
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 201 of 203, by Major Jackyl
I decided to do PCChips M861g(1.6a) because it looked like I could get it done quickly, not many caps.
The attachment 20251004_152520.jpg is no longer available
I initially was just going to to the power stage, it had some puffers, but I ended up doing the whole thing. 34 on this one. Most of them tested fine, just the puffers were actually bad.
The attachment 20251021_205321.jpg is no longer available
The attachment 20251021_205332.jpg is no longer available
The attachment 20251021_205357.jpg is no longer available
I'm about to test it soon. If it works, I'll prepare a drive for it. I recently got a pile of 40 and 80 GB Seagate 7200.7, so I've been pairing boards to drives.
The attachment 20251021_211401.jpg is no longer available
Reply 202 of 203, by Major Jackyl
Alright! It POSTed first try and then sailed right into DOS and completed the first test. It failed the memory test, but I'm not surprised by that.
The attachment 20251021_225254.jpg is no longer available
What I AM surprised about, is how many boards this stick has gone through and NONE of them have detected the failure. (this is a 1GB stick, always detected as 512MB) After the first restart, the BIOS also told me my memory was crap. I've never seen it straight up say "Extended memory test FAILED, F1 to continue" or something like that. I switched the sticks out for two random ones, both worked and passed both BIOS and Speedsys memory tests. I ended up changing RAM yet again, so I could tune it properly (was DDR333, now I got 2x512MB DDR400).
All my testing was with the onboard VGA so far. WindowsXP doesn't know anything about it and the Hyperion drivers did not contain video drivers. I didn't want to bother with the onboard anyway, so I tried installing the 9600LE. It wouldn't output video and after a few reinserts, wouldn't POST anymore. Removed, it POSTed, but the 9600LE was NOT working. I tried the universal GF2MX200: it POSTed AND gave me video.
Next problem:
3Dmark2001 crashes as soon as the first test starts to load. Ugh. I felt I already knew the problem, so I went right for that: the VIA driver for AGP. I just reinstalled the microsoft basic driver in the device manager and restarted. It was now able to run 3Dmark2001... almost. It crashes randomly now. HARD crash, dead-reboot.
I'm working as I'm typing, so I got updates already. My gut was telling me what's wrong. The PSU. I ran out of PSU! I swapped the PSU (300W Enermax) with a Antec TruePower 650 and it was able to complete the test! It is also a much smoother experience at the desktop.
The attachment M861_3DMARK_MX200.JPG is no longer available
The attachment 20251022_180340.jpg is no longer available
The 9600LE works in the board now, too! I've tried doing another run with the 9600LE and got the boost expected.
The attachment M861_3DMARK_R9600LE.JPG is no longer available
Seems like a good board so far. I don't like the driver situation, but it works pretty good. I'll continue testing.
While I was doing that, I also disassembled the empty XT -style frame and will wash it before getting some fitment details worked out. I'm going to need to make a few parts for it to be completely usable.
The attachment 20251022_195517.jpg is no longer available
I don't know the status of the PSU that came with it. It was opened before and will need to be again.
Reply 203 of 203, by Major Jackyl
Just did some quick mock-up to get to know what I'm working with. I started with a "modern" board.
The attachment 20251022_214732.jpg is no longer available
I then tried a board without audio, to add more clearance for the expansion slot bracket.
The attachment 20251022_215019.jpg is no longer available
I moved to try and take care of the other clearance issue: the drives
The attachment 20251022_215215.jpg is no longer available
The easiest route, of course, is a baby AT board, but...
The attachment 20251022_215435.jpg is no longer available
This Gemlight, I knew was going to fit already, so I also threw a bunch of stuff on top to eye-ball clearances.
The attachment 20251022_220214.jpg is no longer available
Not sure which direction I want to go yet with that.
The M861 is still trooping along well, no issues. I'll call it good by tomorrow.
