First post, by Nemo1985
Hello, do anyone have any idea about the differences of th 2v version compared to the 2?
From the little information I could find on the web apparently the 2v is a die shrink of 2.
What I wonder is: will consume less power? Does it help with overclock?
Any performance difference at the same clock?
If anyone has the two cards would be available to do some shorts test?
Thanks
Reply 1 of 2, by Putas
I did not find any differences except better overclocking.
What do you want to test?
Reply 2 of 2, by Nemo1985
Putas wrote on 2025-10-24, 06:41:
thank you for the clarification.
Since you mention there are no performance differences, I'd say a final reality benchmark at stock and overclocked frequencies can be enough.
If my memory doesn't betray me the clock of memory and core is tied and different cards used different speed memory, most common are 10ns but there are others with 8 and I thought I've seen even a 7,5.
I've found this card which seems perfect, 8mb, agp with permedia 2v but I can't understand the rated speed of the memory chips.
The attachment backcard.jpg is no longer available
