IBM APTIVA 2144-M63 BUILD - BIG UPGRADES
Reply 140 of 144, by Ottersphere
Yeah, I’m curious what the P/N and FRU are for your L2 Cache COASTs as well?
Reply 141 of 144, by Señor Ventura
KSHIRZA1 wrote on 2018-03-18, 06:27:
Interesting... the heat sink of my pentium 120mhz is not enough for a p200 (no mmx), i understand... right?.
What could i adapt?
Reply 142 of 144, by isaacx0
IBM Altiva and Model M, AWE64 soundcard, and TMNT poster and merchandise... Neato. I used to have some of those same toys as a little kid.
Testing some alternative OSes por distros on that rig may also be interesting to see (OS/2 Warp, NetBSD, some GNU+Linux even)
Reply 143 of 144, by TheDudeLasse
Señor Ventura wrote on 2025-09-04, 18:08:
What could i adapt?
I upgraded to a Pentium 200 MMX (which can only run at 166 MHz on this system), but I rigged a 120 mm Noctua fan to blow air down from the top of the heatsink to keep the CPU and surrounding components constantly cool. Seems to work well.
Reply 144 of 144, by TheDudeLasse
Ottersphere wrote on 2023-08-09, 20:57:
Have you managed to find an L2 Cache COASTs stick for your system... I've also been searching for one, but these seem to be very hard to come by.
