Though it may help with 3D routines a tiny bit, due to the way they work, how they run.
Similar to how the 68010 helped here (it had a tiny buffer which helped with code loops).
The 8086 had to calculate a addresses and jumps through ALU, had no dedicated unit for it.
Such calculations might be easier to V30, not sure.
The V-series has INS and OUTS commands for string operations, which can improve performance a lot.
- Provided that software makes use of it.
Unfortunately, I don’t know much about the The Colony engine.
Except that it pioneered colour graphics on Macintosh, sort of.
Does it support any FPU, for example? 🤷♂️
https://www.youtube.com/watch?v=i1XENlUUOhA
https://www.youtube.com/watch?v=3k3qrt76Ddk
https://www.youtube.com/watch?v=laqTN5xobVE
Edit: I've tried the game on my 4,77 MH XT with V20 CPU and VGA card (and 8087).
It was at around 2 FPS, I think. In EGA graphics mode (640x350 16c).
Given that the M24 runs at about twice the speed and has 16-Bit memory, it might end up running even better with a V30 processor.
I don’t know how quick the M24 graphics bord is, though.
