Reply 140 of 156, by shevalier
 - Oldbie
Ozzuneoj wrote on 2025-10-28, 18:58:Also, there's little point in even mentioning 32bit 384Khz audiophile\studio grade DACs these days. DACs with those specs cost pennies now. I have bought several 32bit 384Khz USB-C to 3.5mm DAC+Amp dongles from Aliexpress for $4 over the past couple years and they work and sound great to my ears hooked up to some cheap IEMs. If you can buy this on Amazon for $6, those specs are no longer telling us why we should be spending $500 on this new Sound Blaster thing.
When I clicked the link in my email and started scrolling down the Kickstarter page, I thought to myself... "Okay... lets guess. It's going to be $129 for the starter set, with the add-on being like $79."
I was floored when I saw the kickstarter (investor\early-adopter) pricing was $300+ and actually laughed when I saw that the MSRP will be $500.
The main problem with audio is that everyone thinks they understand audio. 😀
If a device specifies 32/384, it only means that it supports receiving data in this format.
Distortion and noise data are simply copied from the datasheet onto the chip.
There is a huge difference between a reference implementation and an end-user implementation.
The 24-bit ASUS STRIX 2 was actually 11-bit.
And it didn't cost $6.
https://www.audiosciencereview.com/forum/inde … ound-card.4915/
So no, for "$6," you're getting exactly $6 worth of quality.
But even Creative in its current form, unfortunately, won't release anything worthwhile.
I'm skeptical.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64  ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
