First post, by octopus
I have a TC430HX socket 7 motherboard, which is my main retro machine.
It has an onboard connector for floppy drives, however that seems to malfunction.
The drive gets detected and I can read floppy's, boot from them etc. I can not write floppy's.
After analysing and testing, my conclusion is that the issue resides on the mainboard side.
What I've tested:
- change disk drive: same result
- change band cable: same result
- check BIOS settings: there is an option to make the drive read-only. I've set that and afterwards put it back to read & write, so the setting is written again. Results are the same
- add ISA controller card and connect the drive there: the drive works fine, both read and write options
My question is: can there be a way to fix the motherboard connector? Can you help me figure this out and what would you need to help me on that?
If there is no way to fix that, I'll stick to read only and keep my eyes open for an extra ISA floppy controller card (I have only one and that is in use in another machine).
Looking forward to your thoughts!
