First post, by GloriousCow
I've released an CPU test suite for 286 emulators, similar to my previous tests for the 8088, 8086, and V20.
https://github.com/SingleStepTests/80286
Again, these are hardware generated tests, made by controlling a Harris 80C286 CPU via an Arduino microcontroller.
Currently, only real mode tests are present. The test suite contains 326 instruction forms, containing nearly 1.5 million instruction executions with over 32 million cycle states captured.
This test suite is released in a chunked binary format I call MOO. A script is included to convert them into the traditional JSON format if you'd prefer.
The binary format was designed to be easier for emulators written in languages like C to use and example C code for reading MOO files is provided here:
https://github.com/SingleStepTests/8088/blob/ … ls/moo_parser.c
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 2 of 8, by xsaveopt
Very cool!
If you're planning on doing protected mode tests as well, I've found `((random() << random_range(0..32)) >> random_range(0..32)) ^ (random_bool() ? 0xffffffff : 0)` to be quite helpful in (quickly) generating test cases that cover all behavior. And for cmpxchg(8/16b) you'll also need some percentage of test cases to have random registers/memory set to equal values.
Reply 3 of 8, by GloriousCow
xsaveopt wrote on 2025-07-26, 13:55:
Very cool!
Thanks!
I do inject all-zeros and all-ones at around 5% odds for registers, memory and immediate operands, but I like that shifting idea a lot too.
The main thing I need to figure out for protected mode tests is how to heuristically produce descriptor table values that provide a reasonable percentage of success.
cmpxchg was introduced on the 486 was it not?
Reply 4 of 8, by xsaveopt
GloriousCow wrote on 2025-07-26, 15:45:
There are some instructions where you're statistically just not going to be able to cover all behavior if you use only uniformly distributed random numbers. For example, for the two and three operand imul instructions you're virtually only going to see overflows.
Maybe you could do this iteratively? From the segment registers you know which ~6 or so descriptors could be accessed by an instruction, so you could start by filling those with the least restricting descriptors possible. If that executes successfully, you can do a few mutations making the descriptors more restrictive until it eventually does give you a fault.
My bad, you're right. I've mostly been looking at recent CPUs so I didn't realize that instruction wasn't available on the 286. I think it might also relevant for the flags of the cmp/sub instructions and maybe the termination behavior of rep cmps/scas, but I'd have to double-check that.
Reply 5 of 8, by GloriousCow
xsaveopt wrote on 2025-07-26, 16:23:
I use a beta distribution instead of a uniform distribution, which helps a bit. I don't believe imul faults - idiv of course throws exception 0. I have the stats on this . 16-bit IDIV throws exception 0 in 3224 of the 5000 tests. Not ideal.
The worst performer is BOUND, which "fails" 4351/5000 times. The chances of one random 16 bit value being between two other random 16-bit values is just not that great.
I had an idea to leverage my emulator when I had an implementation, to just dump test candidates as the emulator ran for various opcodes in real protected-mode software. These could then be run through the CPU to capture the actual cycle states.
Reply 6 of 8, by xsaveopt
GloriousCow wrote on 2025-07-26, 17:17:
It doesn't fault, but it sets CF/OF based on whether the result overflowed or not. So you would end up with only outputs where CF/OF are set. Whether that's relevant depends on what you're aiming to do with the tests I guess. For my usecase it was, which is how I ended up with the bitshift.
Reply 7 of 8, by GloriousCow
xsaveopt wrote on 2025-07-26, 18:34:
I'll give the shift method a try.
I do track flags that are always-set or always-cleared in a test set and validate they match documented values. For the 286 test suites, i do not see IMUL always setting OF, but it could be 99.9% I suppose.
Some of them don't get there , like the z flag doesn't get set in all DEC tests because I don't inject 1.
Reply 8 of 8, by GloriousCow
I've updated the 80286 CPU tests to version 1.1.
The top four bits of the initial flag state are now masked off - they can't be set in real mode, so having them sometimes set in the initial state was a bit confusing.
A bug affecting the flag address in the exception chunk when SP was odd is also fixed.
