First post, by Qwseyvnd
I have been searched around the internet without finding decemt explanation to run it. Any workaround?
Greeting from Øyvind Hagen.
Reply 1 of 5, by Zup
Some thoughts...
- FS95 - The page on PCGW states that running it using compatibility settings would be enough.
- FS98 - It uses some kind of CD protection, but PCGW doesn't list it.
- FS2k / CFS2 - I've got those and made it work in Windows 10. They use Safedisc, so they won't work unless you get a no CD patch. Also, they need to be properly installed (from CD or CD images)... I don't know what DLLs do they need, but they won't work if copied around.
I'm selling some stuff!
Reply 2 of 5, by Qwseyvnd
Ok, thank you for information about FS98 and I will trying nocd for FS2000.
Reply 3 of 5, by Torturephile
They don't work properly. FSfW95 will crash when changing the views, specially backwards. FS98 will not run at all. They don't like 64-bit Windows at all. Best bet is to run them on Windows 7 32-bit, virtualization or not. Later 32-bit Windows give FS98 issues displaying the 2D panel in hardware rendering, though software rendering will be fine.
Reply 4 of 5, by Lifeisstrange74
Torturephile wrote on 2025-02-06, 05:32:
DDrawCompat should be able to fix that, it fixes the 2D panels freezing the display in CFS1.
Reply 5 of 5, by Qwseyvnd
Hmm... Okay.
