midgard wrote on 2026-01-07, 00:55:
For sound mayby Soundblaster LIVE/AUDIGY for Windows and ESS-Solo for Dos OPL. You could probably run them in paralell if no conflicts.
Yamaha YMF PCI card would work well for DOS also.
Thank you for mentioning all this!
Indeed I have following hardware waiting to be assembled / put in one of my planned future retro PC projects:
FX 5600 AGP (I have 2x of them)
FX 5200 AGP,
GF 4 Ti 4200 AGP,
GF 3 Ti 200 AGP,
Riva TNT2 M64 - 32MB AGP
V3-2k AGP (I have 2 of them)
V3-3k AGP (I have 2 of them)
Matrox G100 AGP
Matrox m3d PowerVR2,
Diamond V1 with 4MB I bought yesterday to replace the Miro 6MB,
Canopus Pure 3D 6MB (I will sell it, as I don't need 2x 3dfx V1 with 6MB)
AWE64 value (I have 2 of them) ISA
PicoGUS 2.0 (I have 2 of them) ISA
Yamaha 192 DXG YMF724-E PCI
SV 550 YMF724-E PCI
SB Audigy 1 (I have 3 of them)
SB Audigy 2 ZS
QDI Brillian S1 with 440BX FSB 100 only + 450 Mhz P3-Katmai
QDI Brillian X with 440BX and FSB 133 + 533 Mhz, 550 Mhz P3-Katmai (I bought 3x Katmai CPUs when the were cheap)
Asus CUVX-2D Dual with 2x P3-1Ghz Coppermine
Asus CUSL2-C with 1x P3-1Ghz Coppermine
Samsung 80 GB HDD
Seagate 80 GB HDD (I have 2 of them)
8x 32GB sd-card SanDisc along with SD2IDE adapter
LG H24N IDE (I have 2 of them)
LG H60N SATA H58N SATA along with SATA2IDE adapter
Toshiba 240GB SATA 3 along with SATA2IDE adapter
Ali 5271 USB 2.0 PCI card (I have 3 of them)
Ali 5271 USB + Firewire PCI card
IDE UDMA 66/100 PCI card
Intel FastEthernet 100 PCI card
Adaptec AH2940 SCSI Ultra
SCSI CDROM drive UltraPlex 40max
sold as the turned out to be useless:
1. Elsa Erazor Riva 128 PCI
2. Elsa Erazor Riva 128 AGP
3. Elsa Winner Trio64 PCI
Current PC retro project I m developping now step by step:
Asus P5A
AMD K6-3 / 400 => will never oc, as I want to look back and run most good DOS and some few good WIN games 1992-1998
64MB SDRAM (I have bought 3x 128MB and will put them in as soon as they arrive)
Spea Mirage Trio64 PCI 2MB (in Bios I can switch init display first to PCI/AGP to use it under MSDOS 622)
Rendition Verite v2200 AGP 8MB (for all DOS and WIN Rendition games)
Miro Hiscore V1 PCI 6MB (for all DOS and WIN Glide games)
Future desire: Matrox m3d => in case I succeed in installing it properly in Win98SE I would have 3 several propietary graphics api (Glide, RRline, PowerVR) along with D3D and OpenGL
ESS1938 onboard sound chip => it functions 100% under MSDOS 622 and I hope I can make it run Direct Sound on Win98SE
AWE64 value ISA => DOS / WIN
Pico GUS 2.0 ISA => DOS only
32GB sdcard (3 partitions, FAT16,FAT32,FAT32)
LG H24N DVD-RAM burner SATA
Primary FAT16 MSDOS622 - 2GB
Ext/Logic FAT32 Win98SE - 4GB
Ext/Logic FAT32 - 26 GB
To my surprise: even Deus Ex 1 runs ok with DX 7.0 along with either v2200 D3D renderer or V1 3dfx renderer with 640x480 low details
To my 2nd surprise: I was able to run Quake 2 on V1 with 22.1 fps for a short time. After installing a new driver I got a blue screen then de-installed it, re-installed the older one and once again 9.5 fps (no idea why).
Btw: because of my goal 1992-1998 games I use ChatGPT which is advising me how to use STMUL to slowdown in case I wanted to play U7, Wing Commander and other speed sensitive games.
At the moment I m focusing in installing the best drivers for the V1 and the v2200, Quake 2 must achieve once again the 22.1 fps.
Furthermore I strive to make it possible to run the Solo1 onboard sound chip along with the AWE64 under Win98SE and furthermore along with AWE64value and PicoGUS 2.0 under MSDOS 622.
Fortunately ChatGPT has transformed Phils DOS Boot menu into an advanced with choice between the 3 sound cards, either of them running fine at the moment.
I will post the final results here as soon as I succeed in installing and making everything stable.
PS: forgot to mention, that I have ready another 2 Retro PC ready to play, this means not all the hardware above is alone:
1. Asus CUSL2-C Intel 815P, P3-1Ghz Coppermine, 512 MB SDRAM PC133, MSI FX5600, SB Audigy 1, Ali 5271 USB+FireWire card, Toshiba 240 GB SSD with SATA2IDE adapter, LG H60N with adapter (dgVoodoo 2 emulation will run here)
2. QDI Brilian X S1 Intel 440BX FSB100, P3-450 Katmai, 768 MB SDRAM PC133, V3-2k, AWE64 + 32MB SIMM adapter, PicoGUS 2.0 + 32GB MT32/GS/GM adapter, Samsung 80GB HDD, LG H58N with adapter
The games I played on these 2 Retro PC: Deus Ex 1, WoT, Quake 1, Quake 2, Tomb Raider 1, Midtown Madness, Doom 1, Doom 2, Hexen 1, Hexen 2, Heretic 1, Heretic 2
The last 2 weeks I spent a lot of time in developing my AMD K6-3 400 rig (MSDOS 622, Phil's boot menu, Win98SE dual-boot, finding drivers for v2200, V1, Ali 5 AGP vgart 1.82, AWE64, ESS1938, a lot try and error)
DOS:P233MMX,64MB,ECS,SpeaMirageV7,3dfxV1,AWE64,ESS1868,PicoGUS,32GB
W98SE:K63/400,256MB,P5A,Verite2200AGP,3dfxV2,M3D,AWE64,ESS1938,PicoGUS,64GB
XP:P3-1G,512MB,CUSL2C,FX5600AGP,Audigy1,80GB
