First post, by jmk
I have been working on Covox Sound Master emulation... I am still trying to get to grips with the specs and how DMA sound works and so on, but I can play AY and samples with a few glitches and lock ups, depending on the game.
The only game I've found that supports the AY8930 properly (duty cycles and separate envelopes) is Where in Time is Carmen Sandiego? 😁 Nothing seems to use white noise though. 🙁 You'd think that people would've ported some of their Atari ST musical assets...
Firstly:
The Prince of Persia detection routine sets up a DMA 1 & 3 transfer and then reads port 08 (DMA status) to determine which one (if any) took place.
The routines reads the port and decides that if bit 7 is low then DMA 3 has occurred or if bit 5 is low then DMA 1 has occurred. Generally not what happens in the DMA emulation, where those bits are high or low depending on whether a callback routine has been attached. (For now I am rigging it).
Secondly:
If anyone has a Covox Sound Master+ and can reveal a bit of information on it (even just listing the chips on the board) then I would be grateful!
The CSM appears to use Base+0 to Base+4 for its AY, DAC and DMA (fine). The CSM2 seems to use Base+8 to Base+F for its DAC and DMA (fine, plus the usual Adlib ports for its OPL2 chip). The CSM+ is presumably similar to the CSM, but with an OPL2 chip added. The thing is, the CSM uses some of the AY registers to set up the DMA, so... does the CSM+ have the OPL2 and AY-3-8930?
Reply 1 of 18, by Great Hierophant
I recall reading once that one of the Alone in the Dark (2 maybe) games supported the Covox Sound Master Plus. or the Media Vision Pro Audio Spectrum Plus. In either case, this is delving into the truly obscure if this is the best we can come up with. I encourage full support for the non-FM Sound Master. I do not recall any one else having emulated the AY-8930.
Reply 2 of 18, by jmk
It is astonishingly hard to find any Covox Sound Master information, anything at all will be appreciated. 😀
Alone in the Dark (and other games) seem to have been a bit loose with their description of which CSM card they actually supported. The setup program says "Covox Sound Master+". It appears to do a CSM2 detection, when that fails it is quite happy to play a DAC at 022F using the timer interrupt, which is definitely CSM2/Voice Master compatible, but is it really CSM+ compatible?
To confuse things further, most of the AITD box shots on MobyGames actually show "Covox Sound Master 2+"! I think the Spanish one is the only one that actually says "Sound Master+".
My main reason for requesting CSM+ info was that I wanted to be able to demarcate the hardware between each card, especially since some detection routines wanted to use the newest model available (ignoring AY when it finds OPL and using CSM2/VM samples instead of the AY sample method). If the CSM+ is a full CSM with an added OPL2 chip then it would be impossible not to support it, as any attempt to have CSM and SB activated at the same time would create Adlib at ports 0388.
The AY8930 is (mostly) not that difficult an upgrade from an AY8910/YM2149, but the noise generator does seem a lot more complicated, hence why I was (and still am) looking for some software that supports it in AY8930 mode.
Terms:
  • AY = Plays AY using 8910 features.
    AY8930 = Plays AY using 8930 features.
    AYDMA = Uses the DMA sample method using AY registers.
    DAC 0222 = Uses timer interrupt to write 8-bit samples to port 0222.
    DAC 022F = Uses timer interrupt to write 8-bit samples to port 022F.
    OPL2 = Uses Adlib ports (usually in preference over the AY).
    CSM2? = Probably CSM2 compatible only.
    Nothing = No port or BIOS activity seen.
    WN = Supports AY white noise (none so far!).
Here is my current list:
  • Ultima 6 (AY)
    Sim City (AYDMA) (Freezes)
    Big Business (DAC 0222 or DAC 022F)
    Sim Earth (AY)
    Space 1899 (DAC 0222)
    Prince of Persia (OPL2, AY, AYDMA)
    Spirit of Excalibar (AY) (Crashes)
    Vengeance of Excalibar (AY)
    Conan - The Cimmerian (AY)
    Megatraveller 1 (DAC 0222)
    Megatraveller 2 (AY, AYDMA)
    The Punisher (OPL2, AYDMA) (Plays erratically and freezes sometimes).
    BattleTech: Revenge... (OPL2, DAC 0222)
    Millennium (AYDMA)
    Twilight: 2000 (AY, AYDMA) (Crashes)
    Where in Time is Carmen Sandiego? (OPL2, AY8930, AYDMA)
    Where in the World is Carmen Sandiego? Enhanced. (OPL2, AY, AYDMA).
    Galleons of Glory (OPL2, AY, AYDMA)
    Joe Montana Football (OPL2, DAC 0222)
    F-14 Tomcat (OPL2, DAC 0222)
    Alone in the Dark (OPL2, DAC 022F, CSM2?)
    Shadow of the Comet (OPL2, DAC 022F, CSM2?)
    Grandmaster Chess (OPL2, DAC 0222)
    Wizardry 6 (DAC 0222, DAC 022F)
    Wizardry 7 (OPL2, CSM2?)
    Pinball Dreams/2/Fantasy (CSM2?)
    Cobra Mission (OPL2, CSM2?)
    A-Train (Nothing)
    Countdown (Nothing)
Reply 4 of 18, by jmk
wd wrote:
Maybe check out the games at
http://www.mobygames.com/attribute/sheet/attributeId,80/p,2/
if you didn't already, and maybe test the win3x drivers for those cards.
I had a look at the Win 3x drivers and, strangely, they didn't support DMA for the older cards!
I've been on a busy work schedule for the past month, so I haven't been able to do any work on Covox stuff. Unfortunately, I'll be busy for another month as well... Maybe late August might give me some time.
Reply 5 of 18, by Great Hierophant
Excellent work though, hearing AY sound at all is a real treat. It is especially encouraging (if only for emulation purposes) that no game seems to use the white noise capabilities of the AY8930, whether enhanced or not.
We believe that we know that the original Covox Sound Master used only an AY8930 for non-digitzed music generation, and the Covox Sound Master 2 used only an YM3812 for non-digitzed music generation. The question is whether a Covox Sound Master + used both.
The hypothetical CSM+ would have an AY8930 and a YM3812. The AY8930 would have been placed primarily for DMA purposes while the YM3812 would be present for Adlib compatibility and "better" music. However, a program could use both for music, but as you say virtually all would autodetect the OPL2 chip and use it as the better chip over the AY8930 PSG chip. The same result would be obtained if a user has a CSM and an Adlib card in his system.
This issue is similar to my trying to identify the capabilities of a Pro Audio Spectrum Plus card, as distinguished between the Pro Audio Spectrum and Pro Audio Spectrum 16. In that case, I learned from looking at the board is that it had the OPL3 and 8-bit capabilities of a '16 and the mixer and stereo chips of an 8-bit PAS.
Reply 6 of 18, by thatroom
If I'm not misinformed, either the MAME or MESS tree may possibly have emulation of that particular chip.
Reply 7 of 18, by mratzloff
jmk wrote:
Here is my current list: […]
  • Ultima 6 (AY)
    Sim Earth (AY)
    Millennium (AYDMA)
    A-Train (Nothing)
    Countdown (Nothing)
FWIW, Transylvania III: Vanquish the Night also has support for Covox Sound Master, as well as the Covox Speech Thing.
Reply 8 of 18, by elianda
Well I just searched google for Covox Sound Master Plus and found this thread.
And I got a Covox Sound Master Plus.
http://mail.lipsia.de/~enigma/neu/pics/covox_sm_plus.jpg
Now as you can see there is only a OPL2. As far as I know, the 8 Bit DAC is located at 0x330.
I have tested it with Lemmings Covox Edition and Wolfenstein Covox. (there is a command line parameter).
Can't add much here, but the card is working. So if you think you need to test something according the DAC with the real card, send me a test program.
For the AY8930 all I found is the chip datasheet.
http://www.datasheet4u.com/download.php?id=542002
Youtube Channel
Reply 9 of 18, by jmk
Oh! How did I miss this! 😅
Wow, a real CSM+ card! Thanks for the picture. I wonder, did it have a utility/demo disk included?
1 OPL2, no AY and a DAC at 0x330... strange, certainly unexpected. Impossible to tell if it has any DMA playing from the picture alone.
Rigging up a test application is something I will get around to, as soon as I can. For now, could you try one of the Pinball Dreams / Pinball Fantasies games? Any one with SETSOUND.EXE has the option to select a DA Converter which you can enter a custom address into, so if you could try that and set the address to 0330 then we could find out quite quickly if the DAC really is there! (Make sure you don't have a SCSI drive though. 😉 ) Also, if you could try any of the games listed in my earlier post (in this thread) that uses AYDMA (Millennium is a good example), just to see if they've used any logic chips to implement the old DMA method without the AY. Many thanks.
I've tried Covox Lemmings in a hacked Dosbox, but I don't detect any access to port 0330... Just OPL2 at 0388.
Also, thanks to mratzloff for the Transylvania III tip, although I can't get a peep out of it. If you have that, then maybe you could try it too?
Reply 10 of 18, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The back side of the card would reveal if it uses DMA. Looks too primitive for that though.
1+1=10
Reply 11 of 18, by ih8registrations
I submitted a correction to mobygames about this a long time ago, included a reference this thread, about splitting sound master from sm+/II and adding the games you had cataloged with support. It sat, and sat, and sat, till finally they deleted the entry with no reply about a decision. Only by checking the sound device list to show nothing has changed.
Reply 12 of 18, by jal
Mail Trixter directly, he's usually quite responsive.
EDIT: You could also PM him, he's a member of this board.
JAL
Reply 13 of 18, by MobyGamer
Well, I used to be quite responsive 😀 But I have good news: I was gifted a Sound Master Plus with the driver disk, and while it was failing, I managed to get all of the data off of it. I've uploaded the Covox Sound Master Plus Program Disk here:
http://archives.oldskool.org/pub/drivers/Covo … 0Master%20Plus/
Of particular note, found in some of the files:
             (NOTICE: The first production runs of the Sound Master Plus
card had wrong information printed for the DAC port address
settings only. The printed information might read 330 and
338. The 330 actually represents DAC port address 22X, and
338 actually represents DAC port address 24X.)
I believe this answers some confusion about this card.
Reply 14 of 18, by jal
Thank you. That must've been the longest time between a question and a follow-up on this board - almost 16 years 😄.
Reply 15 of 18, by MobyGamer
I didn't have the board, or drivers, until a few days ago 😀
Reply 16 of 18, by Benedikt
MobyGamer wrote on 2025-11-05, 01:01:
Well, I used to be quite responsive :-) But I have good news: I was gifted a Sound Master Plus with the driver disk, and while […]
Wait a minute... Isn't the Covox Sound Master Plus an AdLib compatible card without the AY8930 that the Covox Sound Master (ab)uses for DMA timing?
Unfortunately, I cannot offer all that much information on the DMA functionality, either, because my attempts to emulate the Covox Sound Master in PCem do not cover any DMA functionality, yet.
Reply 17 of 18, by Grzyb
Benedikt wrote on Yesterday, 09:45:
It is.
Covox Sound Master and Covox Sound Master Plus are totally different.
Covox Sound Master Plus = AdLib + direct DAC. Nothing to do with DMA.
Nie rzucim ziemi, skąd nasz root!
Reply 18 of 18, by jal
MobyGamer wrote on 2025-11-05, 20:45:
The fact you remembered this thread is amazing though 😄.
JAL
