Reply 2420 of 2421, by feipoa
- l33t++
I'm unable to give up DOS CD-ROM access. It's too inconvenient for those later games with disc checking.
To be clear, I'm not overclocking the UMC IDE controller. I am running it at 33 MHz. If it's run at even 40 MHz, the UMC DOS driver won't load w/Cyrix 5x86.
It would be interesting to see if CF cards supporting block mode, or multi-sector transfers, suffer the same fate on the UMC IDE controller. So far, I haven't run across such a CF card, but Mouser sells them for around $300 for an 8 GB card. Other than seek, late era mechanical HDDs, usually from about 2006 or later, offer similar or slightly better throughput to CF cards. There are USB 3.0 to IDE adaptors available now which would make cloning more convenient. I'm using a USB 2.0 to IDE adaptor now and its way too slow for cloning with dd.
