First post, by Gelip
Host OS:
WinXP SP2 64-bit
Microsoft Virtual PC 2007 SP1 6.0.192.0 x64 - https://web.archive.org/web/20130504104132/ht … s.aspx?id=24439
Guest OS:
Windows NT Workstation 4.0 SP6
VHD 16 GB, Primary Active Partition FAT32 2 GB, RAM 2 GB, Uniprocessor PC Compatible Eisa/Isa HAL
SCSIPORT.SYS fix - https://bearwindows.zcm.com.au/winnt4.htm#p2
FAT32 drivers FASTFAT.SYS, fs_rec.sys - http://toastytech.com/guis/miscb2.html (http://ashedel.chat.ru/fat32/)
WinXP SP2 Pro loader - BOOTFONT.BIN, NTDETECT.COM, NTLDR
I cannot install Internet Explorer 6 SP1 if use UniATA driver:
UniATA 0.46d8
The attachment 046d8.png is no longer available
UniATA 0.47b
The attachment 047b.png is no longer available
On the standard IDE CD-ROM (ATAPI 1.2)/Dual-channel PCI IDE Controller driver there are no any problems.
Reply 1 of 3, by roytam1
better using default filesystem drivers than unofficial FAT32 one.
Reply 2 of 3, by Gelip
roytam1 wrote on 2025-11-13, 07:22:
I don't want to use FAT16 or NTFS because it annoys me that when we copy some files outside the system, e.g. in WinPE or by connecting the disk to another computer using a USB-SATA adapter, there are errors on the disk - on FAT16 BSOD c0000221 checksum error, on NTFS BSOD 7B INACCESSIBLE_BOOT_DEVICE
I didn't notice any such problems with the FAT32 driver.
To get around the problem, I will install IE6 SP1 first and then the UniATA driver.
Reply 3 of 3, by superfury
FAT16 isn't the same as FAT32. The basic structures are working the same, but 32-bit (FAT32) vs 16-bit (FAT16) is a pretty big difference (64K vs 4G block entries for example).
UniPCemu Git repository
