Ruslan wrote on Yesterday, 19:05:
Judging by the mojo data, there is still some problem. I didn't find any broken tracks, the radio components are fine. What else could it be?
Could you boot straight to DOS, without booting Windows, running cmd prompt under Windows, or dropping from Windows to DOS, then run mojo again?
I have an STB 12MB that was reporting properly in Win98 and mojo (dropped from Win98 to dos). Swapped out with a PA2000 12MB, and this card shows in the cpl fine with all mem and tmu discovered, but dropping from Win98 to dos mojo shows the exact same as yours.
Swapped thr STB back in and it still shows up properly in Win98, but mojo now shows your errors.
Booting straight to dos, both cards report properly in mojo.
K6-3 400 | P5A-B r1.04 | 768MB PC100 | Rage Pro Turbo 8MB AGP 2x | Voodoo2 12MB SLI | Vortex SuperQuad | DreamBlaster x16GS | 3c509B-TP & ROMOS | CF2IDE | ZuluIDE v2 | Gotek 435 | Asus 52x CD-R | SLI fan Bridge | 80mm CPU Fan | Rosewill VSB 650W
