Blood and Dosbox Speed
First post, by yhe1
Hi, I am using Dosbox to run Blood. Trying to make it run faster. Does using the Overlay option speed up Blood, or should I just stay with the surface option?
Reply 1 of 6, by leileilol
Surface should be raw and good enough
A good way to speed up Blood is to buy a new processor
Debian's fucked
Reply 2 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It's different on every computer so try it.
1+1=10
Reply 3 of 6, by yhe1
"Surface should be raw"
What does this mean?
Reply 4 of 6, by eL_PuSHeR
I think he means it's the simplest output. Try also ddraw and OpenGL. You may notice some slight differences depending on the videocard you have.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 6, by valnar
Is there a DOS based benchmark that can show the speed and/or quality differences between choosing the various output formats?
Reply 6 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
run the game's demo mode with fixed cycles and compare the host cpu usage, that's how I do it.
1+1=10
