First post, by palyon1981
This is for a retro PC build I started this past week, the specs are as follows:
Tyan S1856S motherboard, 64MB ram, Voodoo5 5500 AGP, CompactFlash to IDE adapter, Intel Celeron 400MHz.
Basically, Fdisk is not "properly seeing" drives, whether it be a physical 3.5" IDE drive or the CompactFlash to IDE.
Both are seen properly when viewed in the BIOS, currently v1.16, have tried to update to newer versions, but am thrown errors when I attempt to do so.
The CompactFlash card is 32gb, and presently I have it restricted to 2016 MB in the BIOS.
It's absolutely frustrating, I've tried everything to get Fdisk to properly format so I can install Windows 98 on it. Have also tried to boot other operating systems, but all to no avail.
