My 2nd retro pc, what do you think?
Reply 20 of 31, by bitzu101
I finally managed to source out a decent psu with the fan at the back.
You probably noticed in the pics a black psu, and although brand new it s period incorrect.
Just got a antec 80 plus 380w psu with the fan at the back, as it was meant.
Still overkill but that fan position makes all the difference.
Oooo.. And also look what I got in the post...
Full on diablo 2 original cd s...
Reply 21 of 31, by AlexZ
Mondodimotori wrote on 2025-11-06, 22:32:
But thee advantage of an FX5600 is DX9 and the ability to run Glide wrappers with it.
FX series are very poor in DX9, so it cannot be used in practice. For very old glide games the performance may be sufficient.
bitzu101 wrote on 2025-11-22, 11:08:
You are not using P4 CPU power connector and the PSU is rated only 130W for 5+3V. I would say not a good choice. That PSU is for boards with P4 connector only. I looked at my old unused PSUs, and there is a 350W one with 30A 5V rail and total load 185W for 5+3V. It also has P4 connector.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 22 of 31, by bitzu101
AlexZ wrote on 2025-11-22, 12:06:
FX series are very poor in DX9, so it cannot be used in practice. For very old glide games the performance may be sufficient. […]
I reverted , I went for a normal run of the mill 300w psu with fan at back.
TBH , works the same.
Reply 23 of 31, by Mondodimotori
Pretty sure you don't need the grunt to use Dx9 with wrappers for old APIs like Glide.
That's the point of it.
For actual Dx9 games? I would get a more recent GPU, like I did for my XP build: An HD6970, with a GTX 560 Ti as a backup.
Reply 24 of 31, by AncapDude
Boring specs, bad OS, no cable management, upper ODD color mismatch. A 2hr quick build without anything special.
But Yeah, still a machine s1 can have Fun with 🖖
Reply 25 of 31, by bitzu101
AncapDude wrote on 2025-11-23, 06:59:
Live long and prosper!
Yes , it s boring. I do not give a rats axx about cable management nor the color mismach.
As for the os... well... win me is much better suited than 98. I never ever use real dos mode , win me is much faster and I have never had a dos game that will not run in win me.
Also , I have combined my firt retro pc and my second retro.
The socket 370 p3 , i have dismantled and the mb , ram , cpu and cooler went on ebay as a combo. I did keep the case and moved the socket 462 into it. I now have only 3 retro pcs insted of 4. I do have quite a few parts for sale as trying to downsize.
As en experience... the more rare and non boring socket 370 with abit mobo and p3 was totally useless. just like win 98. Very slow build. Yes , very retro , but don t really care about that. The socket 462 is much better , quicker , easier to manage and win me is super fast compared to win 98.
All i need in the end is a win 9x machine. And i chose the faster one.
Reply 26 of 31, by AlexZ
Windows Millenium should work fine with up to 1GB RAM, up from 512MB limit of Windows 98. Your systems were too close apart, so if you don't need DOS then Athlon XP is a better choice than PIII. That Abit board had VIA chipset which is not a good choice for PIII anyway.
Athlon XP with 9x kernels was fast, I kept using it until 2003. It wasn't great with Windows XP due to low ram capacity available at the time.
It's probably best not to have more than 2 retro systems or they end up not being used. PIII/P4/AthlonXP/Athlon64 and s775/AM2(+)/AM3(+)/1155/1156/1366 for later games.
Reply 27 of 31, by bitzu101
AlexZ wrote on 2025-11-23, 10:15:
I found out that the hard way...
but there is a reason for thjat via chipset. As the 462 socket has the same chipset.
It supports DDMA for my ess solo 1 sound card.
Overall , you right , the athlon xp is a much better experience than the p3.
Reply 28 of 31, by MrSegfault
Where do people find beautiful cases like these? I'm pretty jealous.
eBay doesn't seem to have them either.
CPU: Intel Core 2 Duo E7500 2.93 GHz Dual-Core
Graphics: EVGA NVIDI​A GeForce ​7900 GT 25​6MB + Zalman VF9​00-Cu Cooler
Memory: 2 GB (1 x 2 GB) DDR2 Memory
Soundcard: Creative S​oundblaste​r Audigy 2​ ZS
Storage: 1TB + 500GB SSD + 120gb HDD
Reply 29 of 31, by RetroPCCupboard
MrSegfault wrote on 2025-11-30, 02:05:
I got a couple of similar ones on ebay. Just have to be patient.
Reply 30 of 31, by bitzu101
i would have given it to you , but i m in europe...
Reply 31 of 31, by MrSegfault
bitzu101 wrote on 2025-12-03, 20:38:
Aw thanks but I wouldn't accept it either way. I just find it strange how cases like these are really hard to find online these days. They must be pretty rare.
