RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3200 of 3207, by sharangad
Rendition widescreen, unlocked the viewport beyond the top 308 rows of pixels and fixed the aspect ratio weirdness. 16:9's doable. but 32:9 needs a camera offset:
https://youtu.be/4S6X4glexTg
https://www.patreon.com/posts/indycar-racing- … ntent=join_link
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3201 of 3207, by sharangad
Gona wrote on 2025-11-16, 21:12:
I hope Windows 95 is also suitable: […]
sharangad wrote on 2025-09-15, 18:22:
@Gona, could you post the resources used in Windows 98 by your 3DBlaster VLB? I'm interested in ports and address ranges. I hope these are listed in device manager.
I/O range: 03E0 - 03E3
IRQ: 05
Memory Range: C8000000 - C8000FFF
Memory Range: D9000000 - D9FFFFFF
@Gona, could you try running this, it should dump to the screen and produce a log file?
https://nirvtek.com/downloads/3DBVLB.20251123.001.7z
MD5: 8d6f67dea2c45800eb4abbda959845ec
The 3DB blaster initialisation software appears to be reading a byte from IO port 0x20B to 0x303 until it finds what it's looking for. It's looking for a non 0xFF value, but simply returning something other than 0xFF doesn't appear to work.
Reply 3202 of 3207, by Gona
sharangad wrote on 2025-11-23, 12:00:
@Gona, could you try running this, it should dump to the screen and produce a log file? https://nirvtek.com/downloads/3DBVLB.202 […]
IRQ: 05
OK, here it is.
[Unknown] Port 02F7, input value FF
[Match] Port 02FB, input value 03
[Unknown] Port 02FF, input value FF
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 3203 of 3207, by sharangad
Gona wrote on 2025-11-23, 20:07:
OK, here it is. […]
IRQ: 05
OK, here it is.
Thanks Gona! I'll have another test app soonish.
Reply 3204 of 3207, by sharangad
OK, here it is. […]
IRQ: 05
OK, here it is.
Another one for you Gona. I've trapped more ports this time:
https://nirvtek.com/downloads/3DBVLB.20251124.001.7z
MD5: c2e16fec67952415e29dbee22adc73d5
Reply 3206 of 3207, by sharangad
Gona wrote on 2025-11-24, 16:49:
sharangad wrote on 2025-11-24, 07:44:
OK, here it is.
Thanks. That unfortunately didn't do quite what I expected. There'll be another test soon.
Reply 3207 of 3207, by sharangad
OK, here it is.
I think the initial port writes configure a DMA command buffer and actual apps loop until the IRQ is triggered. I mirrored the initial port writes, but it didn't work. Probably because the data I need to send to the VLB needs to present in memory or interrupts need to be enabled, which my app doesn't have. I think the IRQ for the VLB is 3 (I'm probably wrong. Yes I am, it's 5), which might be what the port read returns. I think you listed the DOS config earlier.
Yup in the test app, interrupts are disabled in dosbox at least. I could get you a build to test this on the VLB, but I think it would be mostly pointless. I need to think about this for ab it.
