First post, by NeveroddoreveN
Hey everyone!! I am a newbie with DosBox, and am having a bit of a problem with running DosBox Game Launcher, I really hope someone can shed some light on my situation.
So, I have DosBox-Staging installed, along with Java 25 and DosBox Game Launcher. All of that is set up, but my issue is with the Game Wizard feature. Each time I double-click on the Game Wizard button, I get a message that the "Java Platform SE Binary" is not responding. I have tried a few times, but with each attempt I get the same message.
I attempted to get some help from ChatGPT (I am still a total newbie with it as well), that site said that the latest version of Java that works with DosBox Game Launcher is version 21. So, I went and installed that version, but again, I get the same message as before. Can anyone please help me with this? I am at a loss for ideas and could really use some guidance here. Any and all help is appreciated!! Thanks in advance!!
Reply 1 of 23, by rcblanke
Hi NeveroddoreveN, sorry to hear that. Can you please try starting DBGL with dbglcons.cmd in a cmd window? That way, if the application crashes (as you say, when you attempt to open the Game Wizard) you can see the 'stack trace', technical information about the cause of the problem. If you can provide that information back to me, I'm sure the problem can be resolved.
regards,
Ronald
Reply 2 of 23, by NeveroddoreveN
Hey rcblanke!! Thanks so much for getting back to me!! This whole DBGL issue has been plaguing me for quite some time, I do appreciate your taking the time to write back. I know very little about DOS, which I assume is the reason I have been in this situation for so long. So, to go with what you are suggesting, I am to open a command window and type in "dbglcon.cmd" and go from there? I would be more than happy to, I can't do this now but hopefully tomorrow after work I will have time to dive right in and let you know what the deal is with "stack trace". Seeing as how I am a total DOS newbie, where would the "stack trace" information be displayed? This might be a dumb question, again, I am really new to all of this. I will get back to you ASAP!! Again, thanks so much for responding, I really appreciate your assistance!! Have a great rest of your day, and I will respond to you soon!!
Reply 3 of 23, by NeveroddoreveN
Ronald (rcblanke) - I just wanted to keep you up to speed, I am going out of town in about an hour and will be away till later in the evening tomorrow. I wanted to let you know because I had said I would test out your theory about putting "dbglcons.cmd" in a command window and testing it out, but it looks like I won't have time today. I got off work a little while ago and it's been one thing after another. My apologies!!!
Either when I get home tomorrow, or sometime Friday, I will make sure to do as you have suggested and see where it takes me. I really do appreciate your help, this DBGL issue has been a problem for me for a few months now. I tried the DosBox page on Reddit and the DosBox-Staging Discord, but no one seems to know how to remedy my situation. So I REALLY appreciate your help!! You have been so gracious! Anyway, I need to go pack for tomorrow, I will message you as soon as I can. I hope you have a great rest of your day!!
Reply 4 of 23, by NeveroddoreveN
Good Morning, Ronald, I hope this message finds you well!! So this is the first chance I have had to work on this DBGL problem, I have been busy with family and Thanksgiving, but here I am!! Like I said before, I know just about nothing when it comes to DOS prompt, I went to the command window, found the correct folder for DBGL, found the file dbglcons.cmd file, and typed "start dbglcons.cdm"...the window pauses for a moment before bringing me back to the DBGL folder still within the command window. That's it.
I am sure I am missing something small - I do that from time to time - what are your thoughts? How should I proceed from here? Please write back with your opinion and knowledge on what is going on and what you would advise me to do next. I really appreciate your help, and I look forward to hearing from you soon!!
Reply 5 of 23, by NeveroddoreveN
I went on ChatGPT with this situation, it said that the reason I am having my current issue is because DBGL can't find the Java program. It also said to reinstall Java within the DBGL folder on my hard drive. I am not sure where to put Java in that folder. Side thought - I can either install Java via the x64 installer or the MSI installer. I am not sure how to proceed.
Reply 6 of 23, by rcblanke
Thanks for the feedback NeveroddoreveN. Please download this alternative launcher and store it in your DBGL folder. Then run this file, 'launch_console.exe'. It should start DBGL with a console window with the debug information/output.
Reply 7 of 23, by NeveroddoreveN
Thanks so much for getting back to me so quickly!! Much appreciated!!! I have to say, the DOS games that I plan on running on DBGL are from my childhood, so I am very excited!!!! And I appreciate all of your help!!! As for your post, should I download from the link you sent, extract it directly into my DBGL folder, and I will be all set? I am not familiar with a reference you made, particularly "console window". Could you clarify that a bit? I do apologize, I am not really savvy with stuff like this. And with the debug info/output, is this the same as running Game Wizard? I am trying to learn all that I can about this of thing, I am sorry for all the questions!!! Thanks again!!
Reply 8 of 23, by NeveroddoreveN
I just downloaded the file and installed it into my DBGL folder. I double-clicked on the app, it brought me the same DBGL window. I tried "Game Wizard" again, but still get the message about Java SE Binary not responding.
Reply 9 of 23, by rcblanke
If you've started DBGL with launch_console.exe, you should see both the 'console' output in the form of that black window with text, and the main DBGL window. If you can make DBGL crash, more text should be visible in the console. I need that output, so please make a screenshot, or copy-paste the text in a vogons response.
Reply 10 of 23, by NeveroddoreveN
Alrighty, so I did reload the DBGL Console window (the alternative you suggested), I file and copy/pasted what I saw there on the console window. Here it is!!
Launching DBGL using 64-Bit VM 21.0.8 on Windows 11 v10.0amd64, HSQL Database Engine 2.7.3, SWT v4966win32
Startup
Accepting messages on port 4,740
Your thoughts?
Reply 11 of 23, by rcblanke
Hehe, now make DBGL crash and copy THAT output. 😀
Reply 12 of 23, by NeveroddoreveN
Alrighty!! Sorry I didn't respond sooner, this is my first chance to write back. I just tried the launch_console app, and this is a message I received...
Startup
Exception in thread "main" java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4903)
at org.eclipse.swt.SWT.error(SWT.java:4837)
at org.eclipse.swt.SWT.error(SWT.java:4808)
at org.eclipse.swt.widgets.Widget.error(Widget.java:500)
at org.eclipse.swt.widgets.Combo.setText(Combo.java:2275)
at org.dbgl.gui.dialog.wizard.AddGameWizardDialog.updateControlsByProfile(AddGameWizardDialog.java:388)
at org.dbgl.gui.dialog.wizard.AddGameWizardDialog.onShellCreated(AddGameWizardDialog.java:327)
at org.dbgl.gui.abstractdialog.BaseDialog.open(BaseDialog.java:112)
at org.dbgl.gui.dialog.MainWindow$18.widgetSelected(MainWindow.java:524)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:265)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:91)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4326)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1174)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4124)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3712)
at org.dbgl.gui.abstractdialog.BaseDialog.open(BaseDialog.java:120)
at org.dbgl.gui.Launcher.main(Launcher.java:55)
Is this what you are looking for? Side thought - when I click on "Add Game Wizard", I get the same message saying, "Java Platform SE Binary is not responding". Not sure if that helps you any, I figured I would mention it just in case.
Reply 13 of 23, by rcblanke
Thank you NeveroddoreveN, that is exactly what I need, indeed.
This exact issue was also reported almost a year ago, please see Re: DOSBox Game Launcher (DOSBox Frontend) , and was corrected soon afterwards. I really should release an official DBGL version soon...
If you download my latest DBGL beta build and use that, I believe you'll find the issue resolved. Either use it next to your existing DBGL installation, or just extract all files from the beta archive and overwrite the existing DBGL files.
Please let me know how it goes for you!
Ronald
Reply 14 of 23, by NeveroddoreveN
Awesome, thanks so much!! With the link/download titled, "download my latest DBGL beta build", when I download that, can I put it in a side folder instead of overwriting the DBGL files I currently have on my PC (even though they are faulty)? Or is that what you were talking about when you said to "use it next to your existing DBGL installation"? If all of this is as it should be, and I install the download, I really hope this issue can be resolved!! Please get back to me with an answer (clarification) to my question I am posting here, and I will dive right in!!
Reply 15 of 23, by rcblanke
Correct; You can either extract the beta archive in a new/empty folder so you can check it out without modifying anything of your existing version 0.99 DBGL installation.
Or you can extract the beta archive into your existing version 0.99 DBGL folder, and overwrite all existing files. That will update DBGL from 0.99 to 0.100beta17, obviously keeping all profiles, dosbox versions and tempates you already had configured.
Reply 16 of 23, by NeveroddoreveN
IT WORKED!!!! I am so, so happy that it's finally working!!!! Ronald, you have been a Godsend!!! I downloaded the file, put it in a new, side folder, and just tested the Game Wizard button, it seems to be working just peachy. Now comes a new frontier - using the Game Wizard. I think I have saved a video around here somewhere that pretty much explains how to use the Game Wizard (to a degree), but if you have any suggestions, I would be more than happy to hear about it!! Thanks again, much appreciated!!!
Reply 17 of 23, by NeveroddoreveN
If I have any more questions about the DBGL program, I will certainly let you know. I don't have time to test it out today, but I will be on it as soon as I can. Thanks again for your help!!
Reply 18 of 23, by NeveroddoreveN
A small bit of questions - is the game installation process for DBGL complicated? I found a Youtube video a little while ago but it's pretty vague. I can't imagine it being too hard, but I am having a hard time understanding the video itself. Can you enlighten me, or recommend a video or guide of some sort? What is the process like? And is it beneficial to have the game(s) downloaded previous to the installation? I found a ton of games on an Abandonware website that I am aching to play. I have downloaded a few of them, and I can get the rest of them quite easy. Also, I heard somewhere that the game folders/files need to be within a certain number of numbers and letters. Is this true? And what are your thoughts on all of this? Any and all help is appreciated!! Thanks in advance!! I am almost there!! (haha)
Reply 19 of 23, by NeveroddoreveN
The first screen (after clicking on Game Wizard) asks if the games are installed already... I can download the games before setting this up, is that what the question is asking? I can put them in the dosroot folder, not sure if that would help at all. Your thoughts?
