Reply 540 of 560, by appiah4
- l33t++
Just wondering if it actually did cost less than buying from Serge 😀 I highly doubt it.. I want to make one of my own some day for fun, but I think it would be more hassle than it's worth tbh.
appiah4 wrote on 2021-03-15, 06:11:Just wondering if it actually did cost less than buying from Serge 😀 I highly doubt it.. I want to make one of my own some day for fun, but I think it would be more hassle than it's worth tbh.
Looking at the BOM if you only need one piece shipping is probably going to ruin the value of making your own but if you have multiple cards or make some for your friends as well I think you're going to save quite a bit.
Serge is running a business and has to make a profit, doesn't he?
Doornkaat wrote on 2021-03-15, 07:56:appiah4 wrote on 2021-03-15, 06:11:Just wondering if it actually did cost less than buying from Serge 😀 I highly doubt it.. I want to make one of my own some day for fun, but I think it would be more hassle than it's worth tbh.
I'm pretty sure it's as much a hobby as it is a business for him, it's not his source of main income for sure. I'd wager he makes little money from it if any, he's an extremely generous chap.
Recently I bought original SIMCONN module.
I wonder why I see around that straight vertical or angle socket is used (instead aligned horizontally with pcb to save space) ?
I replaced it immediately in my module.
appiah4 wrote on 2021-03-15, 11:02:Doornkaat wrote on 2021-03-15, 07:56:appiah4 wrote on 2021-03-15, 06:11:Just wondering if it actually did cost less than buying from Serge 😀 I highly doubt it.. I want to make one of my own some day for fun, but I think it would be more hassle than it's worth tbh.
Serge is running a business and has to make a profit, doesn't he?I'm pretty sure it's as much a hobby as it is a business for him, it's not his source of main income for sure. I'd wager he makes little money from it if any, he's an extremely generous chap.
Certainly. Judging from the thread here it seems he's also got A++ service which isn't to be taken for granted at what I guesstimate are his profit margins on something like the AWE64 Simmconn.
I guess if you buy something simple like this adaptor you also support the more complex projects he's got going on.
But if I was going to need 5-10pcs of the Simmconn I'd spend ca. 20-25€ (including shipping cost) plus 10-15min assembly time each if I odered PCBs and parts and assembled them myself.
The ca. 24-29€ difference to the 49€ sales price per unit is obviously not going to be Serge's net profit. (And if it was, good on him! I'm not hating. His shop is cool.) But it would be my net savings.
So assuming you need a few Simmconns if you are handy with a soldering iron and if you can do without product support there is definitely saving potential.
wiretap wrote on 2021-03-15, 02:26:Oh, I'll also note that I tried to program the Lattice 16V8 PAL chips in the TL866II-Plus programmer, and it didn't have that chip listed and other supposedly compatible GAL/PAL chips would erase it but then get a memory error upon programming. (unless there's another trick I don't know)
The Atmel 16v8 PAL chip I have listed at the end of the BOM and in the Mouser cart will work, and I have successfully programmed with the Gold and Value JEDEC files using the TL866II-Plus.
https://www.mouser.com/ProductDetail/556-AF16V8C7JU
when you select the ATF16V8 in the XGPro software there is not a PLCC package option - did it work using the standard chip definition in the included PLCC to DIP-20 adapter?
maxtherabbit wrote on 2020-11-13, 20:31:I think you need a new PAL fisherman
Can you elaborate what you mean by that? I have a dead awe64 and I'm wondering if that's part of it?
P3 Slot 1 - 512MB PC100 - 128GB SSD - RADEON 9200 SE , SB Awe64 ISA - GOTEK MOD
Got my SIMMConn yesterday. I had some random 32MB SIMMs left so it was a bit of a shot in the dark, but so far I couldn't spot any issues with this SIMM - but I only tested it with Imago Orpheus, only using a fraction of the memory (as it's an AWE64 Value, most tracks previously didn't play properly because they used more than 512KB of samples - so I can confirm that the SIMM is definitely being made use of). The SIMM has a number of NEC 424100-60 and 4217400-60 chips, 24 in total (so I suppose it's 16 regular memory chips + 8 chips for parity?). Judging from the labels, the part number of this SIMM appears to be Compaq 139973-002. I have attached a picture of the SIMM for comparison.
I got a used SIMMConn Revival on Ebay and it took some time to get it running. First of all I can confirm that PALCE16V8H chips from Lattice and AMD work with the SIMMConn. (I got them cheap on Ebay.) I programmed them with a Galep 5 programmer. The SIMMConn works without any problem on my CT4500 using a PAL programmed with VALUE.JED and a 32MB memory from SIMMConn recommendation list (HY5117400CJ-60). The same memory is not recognized on a CT4390 using a PAL programmed with GOLD.JED. I've tried all different jumper settings (including one jumper connecting "3" of JP1 and JP2), the CT4390 recognized 8MB, 16MB or nothing. The solution for the CT4390 was using a PAL programmed with ALL.JED and using one jumper connecting "3" of JP1 and JP2. The CT4390 recognizes the 32MB stick using this setup.
Simmconn is finally available again as
separate card : https://www.serdashop.com/SIMMCONN
and as bundle : https://www.serdashop.com/SimmconnBundle
Thanks for your support !
Any recommendation for 32MB modules apart the ones from the list in the shop?
Located in Germany and can’t find any of them
Hi all,
long time ago I become interested by SIMMConn module for memory expansin on AWE64, but I did't have much time to fiddle with, so I left it in the to-do list...
Now I have started to evaluate this project in more detail and found out that there are some problems with memory module compatibility and honestly I wasn't very happy with the overall PCB design. So I redrawed schematic in eagle CAD and made new PCB design. There are some changes and improvements, the most important is added active driver for WE# signal which has high capacitive load and in original design there was only series dumping resistor, although reference design from Creative asks for active driver, maybe this improve that functionality/compatibility issues with some memory modules.
Here is list of the most important changes from original PCB design:
- all parts placed on top side of the PCB
- added active driver for WE# signal
- some data bits for SIMM rearranged for better PCB routing
- added C5 capacitor for SIMM power supply
- JP1/JP2 settings table with complete parameters
- IC1 and IC2 in smaller TSSOP package because of limited space under SIMM module
- SIMM socket only in angled 22deg version
- added fiducials for machine placement of components
I posted my preliminary design here for review, if someone is interested I can send eagle files by email. I'm open to suggestions/critics to fine tune it before I send PCB to production and I plan to put both eagle/gerber files with final version here for everyone.
HMX wrote on 2025-08-27, 08:14:...
Beautiful layout and changes. Looking forward to reviewing the CAD files! Nice work!
I am in the US and just received my SIMMCONN Revival AWE 64 Memory Expansion Card for my GOLD card. However, all the recommended known working 32mbyte memory modules that I can find on eBay are from Europe and are expensive. Here is a seller in the USA that I trust. Can someone point me to one 32MB RAM stick that would work perfectly with my adapter from the articles this seller has in stock please? https://www.ebay.com/sch/i.html?_dkr=1&iconV2 … oac=1&_nkw=32mb
Thanks!
I would prefer thru-hole components. The circuit is simple enough to allow that at that space.
Took a while but finally done!
https://github.com/Blaster-HMX/SIMMConn2
Probably good job but (I am) missing the old-fashioned easy to assemble thru-hole version...
georgel wrote on 2025-11-27, 12:11:Probably good job but (I am) missing the old-fashioned easy to assemble thru-hole version...
There is one problem that I'm aware of. In this improved version, a bus buffer is added for the "write enable" signal, and I used single-gate package for this purpose. But this single gate is only available in SMT package, so only DIP20 full-size package in THT, It's not a very elegant solution and I'm not sure it's worth the effort. Maybe someone has an idea for a replacement?
If you short the buffer do you encounter any problems? It may be possible to use a free input and output on the PLD instead of the buffer but I doubt the buffer is needed at all, could be on some very old SIMM modules with many old chips, these are not 32M anyway...
I only have 32MB simm72 modules with "many chips", there are 16 of them on one double-sided module, so the capacitive load on the #WE signal is significant. And one of the main improvements to this design was better compatibility with these memory modules, where some users have had issues. Also, the change in GAL was not desirable so that the original programmed circuits could be used on the new board.
When I have some free time, I might make an "old-fashioned" THT version based on the original design. Just out of curiosity.
