First post, by hydraphone
- Newbie
I have a Lucky Star 6ALX (i440LX) motherboard with Celeron 466MHz CPU. I got a Sound Blaster Audigy card for it as well. Now, it's time to install an OS on it, but I'm having some issues.
1. The motherboard only has USB 1.1. USB 2.0 slots via PCI would be a nice upgrade. I bought this USB 2.0 PCI card, but when I insert it into any of the PCI slots, the system hangs at boot (black screen) and even the power on/off button doesn't work, I literally need to pull the plug. It has a VT6212L chip.
2. I tried to connect a SATA SSD (120GB) using this PCI card, but unfortunately, the card doesn't seem to have a BIOS on its own, and the AWARD BIOS doesn't detect any disks. It uses VT6421A chip. The one I received is slightly different from the one in the eBay photo, mine has 4 jumpers and a SST 39SF010A chip, it looks like this one
3. ...Which brings me to the StarTech IDE2SATA adapter. I gave it a try, but the BIOS screen gets stuck at "Detecting IDE primary master" with cursor blinking...
I'm trying to understand why none of these items are working. Eventually, it might turn out that it is impossible to get any of those working with this motherboard, in which case I'd appreciate any alternatively that would likely work.
As a side note, the BIOS I have is from 1999, and there is an updated one from 2000, but with the hardware that I currently have, I don't have any means to upgrade the BIOS (the BIOS doesn't support USB booting).
