Reply 20 of 26, by shevalier
- Oldbie
agent_x007 wrote on 2025-11-28, 19:36:I found a bit more difference for '03 for 5600 vs 5200 : NV34U (350/700 = 2215): […]
shevalier wrote on 2025-11-28, 14:57:In short, nothing worked out. The theory has been completely destroyed. With identical RAM timings, 5200 and the same one reflas […]
With identical RAM timings, 5200 and the same one reflashed to 5500 show completely identical results.
Only the numbers in the name of the video card are more pleasant.I found a bit more difference for '03 for 5600 vs 5200 :
NV34U (350/700 = 2215):NV36U (350/700 = 2847) :
Yes, now we can see what the extra transistors were used for.
ciornyi wrote on 2025-11-28, 20:38:Well if its just driver related issue thats sux. As fx 5600 should be at ti 4200 level . And as i have quite a few of those its scores 11k to 15k.
here is based on pentium4 3ghz
Measuring graphics card performance in 3DMark 2001SE is pointless.
It's highly dependent on the processor.
Just put something like Ryzen in there and you'll get 40,000 points.
HWBOT is full of such "fake" screenshots.
PS. Personally, I have the impression that FХ works terribly if the core frequency is not equal to the memory frequency.
That's why Ultras are so good.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
