First post, by retep_110
I am at the verge of building myself a ultra fast winxp retro gaming rig ( wPCI Express)with a GIGABYTE GA-P35 mainboard. I will pull the trigger for the mobo and the cpu tonight.
Im also looking for great sound card. In my thread asking about a suitable mobo the soundblaster xi-fi soundcard was recommended. When searching for that card in the www i found out that there are different models.
Is one model more preferable than others form a pure retro gaming (winxp) standpoint) or would be any x-fi card a good pick?
Reply 1 of 18, by Joseph_Joestar
retep_110 wrote on 2025-12-01, 07:01:
First, you need to decide whether you want a PCI or PCIe version of the X-Fi. Then, look here: https://en.wikipedia.org/wiki/Sound_Blaster_X … Fi#X-Fi_line-up
Avoid any "Xtreme Audio" models, as they don't have hardware acceleration for EAX. Also, don't buy a Titanium HD (emphasis on HD) since it doesn't have WinXP drivers, unlike other Titanium cards. Everything else should be fine, and it depends on how much money you want to spend.
My retro stuff
Reply 2 of 18, by retep_110
Joseph_Joestar wrote on 2025-12-01, 07:15:
Thanks for the info. I was not a aware that there is PCI version as well. I am going to use PCIe mainboard so only the PCIe version is an option. You helped me to avoid a pitfall. Also thanks for providing a link. I will check it out asap.
Reply 3 of 18, by NeoG_
You basically have 3 models you can get;
SB0880 X-Fi Titanium PCIe
SB0886 X-Fi Titanium Fatal1ty PCIe
SB0888 X-Fi Titanium Professional PCIe
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 4 of 18, by ott
Actually, original PCI X-Fi cards (EMU20K1 based) are pretty good in terms of versatility.
I have PCI X-Fi Fatal1ty Edition (with I/O drive) and I'm quite happy with it. I also wanted to get PCIe version Titanium Fatal1ty Champion (EMU20K2), but later changed my mind.
PCI X-Fi Fatal1ty Edition notes:
- Available drivers for Windows XP to Windows 10 (Win 11 also works without memory integrity)
- X-Fi I/O drive fully compatible with older Audigy 2/2ZS cards. In contrast, PCIe version of I/O drive box has been cut down - lacking SPDIF and MIDI inputs/outputs
- Stable work on PCI-PCIe bridge mobos (tested on ASRock Z77 Pro3, Gigabyte B85-HD3-A)
- The card itself looks amazing with gold-color connectors
Reply 5 of 18, by shevalier
NeoG_ wrote on 2025-12-01, 09:33:
You basically have 3 models you can get; […]
All models in the 8xx series are very disappointing.
Creative tried to keep the price the same as PCI cards, but with a more expensive Digital component (RAM&DSP).
Their analog power supply is a parody even of PCI-e Audigy RX v2 (which has a CS4382A DAC, not a CS4382)
If you don't want to be disappointed, go for the Auzen X-Fi Forte 7.1 or Titanium HD.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 18, by Joseph_Joestar
ott wrote on 2025-12-01, 09:47:
Also, I think PCI X-Fi cards aren't subject to the OpenAL bug, which is present on PCIe cards when using newer drivers.
On the other hand, there are reports of PCI cards sometimes suffering from crackling/popping on certain motherboards, but that might depend on the chipset.
My retro stuff
Reply 7 of 18, by retep_110
Thanks a lot for the further information. I will take a closer look at the recommended cards ASAP. Is there anything in particular to note concerning the drivers for WinXP gaming?
Reply 8 of 18, by Joseph_Joestar
retep_110 wrote on 2025-12-01, 11:47:
For PCIe X-Fi cards, you need to use driver version 2.17.0008 or older. Newer drivers introduce bugs with games which use OpenAL (e.g. Unreal 2, Doom 3, BioShock etc).
My retro stuff
Reply 9 of 18, by ott
For original PCI X-Fi:
I prefer latest web driver for Windows XP, it's quite minimalistic and ready for gaming!
Fun fact, it's still available on Creative's site: SBXF_PCDRV_L11_2_30_0004.exe (README notes)
But I need some Creative apps, so I first install the CD driver with selected apps, then install the latest web driver - it automatically uninstalls the old driver.
Reply 10 of 18, by retep_110
Joseph_Joestar wrote on 2025-12-01, 15:51:
That is good to know thanks for the info. I have already thought that using older drives might cause some issues for certain winxp games.
Reply 11 of 18, by greenitse@yahoo.com
Sound on entertainmet and not clear some nois, when I switch tho game mode no sound , I installed 2.17.0008 but no use for my card
My sound card info:
Sound blaster x-fi fatality champion model number SB0880 canadian ices-003 class B and on chipset writen creative CA20K2-2AG hf
Front panel box writen creative SB1110
I tryed in windows 7 and windows 10 and 11 but no use
Plzz any one provide me the correct drivers for windows 7
Note : Sound working but not clear some noise hear
Reply 12 of 18, by Joseph_Joestar
For Win7/10 try using DanielK's latest X-Fi support pack. You can find that on his website.
My earlier comment about driver version 2.17.0008 was specifically aimed at WinXP.
My retro stuff
Reply 13 of 18, by UCyborg
I've been looking around and prices for these cards are nuts, eg. X-Fi Titanium Fatal1ty Champion can be over 200€. Is this normal?
I've read some people being able to get some of these cards for change, like 15€ at most.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 14 of 18, by Joseph_Joestar
UCyborg wrote on 2026-11-15, 10:38:
That's the flagship model with 64MB X-RAM and the front panel I/O drive. Those tend to be the most expensive ones, but that amount is still way too high. Try searching for "sold" listings instead of current offers. That will give you a more realistic overview.
I got mine for 30 EUR from my local classifieds, but that was almost six years ago. I see them going for around 70 EUR now. The non-Fatal1ty models can be found even cheaper, though they come with different amounts of X-RAM, especially the OEM variants. The usefulness of X-RAM (or lack thereof) is debatable, especially if you pair the card with a fast system (Core 2 Duo and up). But it may vary from game to game.
My retro stuff
Reply 15 of 18, by SlowA
I got an SB0886 X-Fi Titanium Fatal1ty PCIe for 10€ in Germany. I wonder if it sounds good, but for that price, it is definitely better than onboard sound.
Reply 16 of 18, by UCyborg
^ That sounds like jackpot.
So far, the cheapest I found is plain Titanium (SB0880) for 30€ or 50€.
Then there's Titanium HD (SB1270) for 120€. Is it true that this one is rarer in general? I know it's also the only one that doesn't work on XP. Kinda odd considering XP was still very popular in 2010. But it was also high-end.
Reply 17 of 18, by badmojo
Yes I've found some locally for 30 to 50 AUD but it did take some patience. There are sellers on eBay who are happy to let things sit there long term with silly prices.
Reply 18 of 18, by UCyborg
There are also crazy shipping prices in some cases.
